Results 1 to 10 of 10
Thread: AutoStart on my alarm
    Twan Jdm94Coupe's Avatar
    Fairburn
    Default AutoStart on my alarm
    i want to know if anybody can put autostart on my del sol(5 speed) cause my work (best buy) wont put it in for me because they say its illegal!! it comes with the alarm but idk how to do it
    ....It is what it is...
    Gwinnett - Grayson
    if your cars not in neutral and you try auto starting whats gunna happen? lol
    2001 Honda Prelude Base model
    http://www.cardomain.com/id/twkg2001
    Quote Originally Posted by Prince NISMO
    he is the mac daddy pimp... rockin the lude all day long!
    Fairburn
    i ALWAYS leave it in neutral, no reason to leave it in 1st gear
    y tu mamá tambien!! Dave's Avatar
    Lawrenceville, GA
    Quote Originally Posted by Jdm94Coupe
    actually there is a reason to leave it in gear. to avoid having it roll down, etc. also if they wanted to tow it (lets say stole it) they can just jack the rear and you can roll it. now if you have it on gear and parking brake you can't roll it in any direction.
    Lawrenceville, GA
    i wouldn't recommend the auto start on a 5 speed. just my 2 cents.
    Monroe, Ga
    when you hook it up put the park wire to your e-brake
    Banned technoteg97's Avatar
    Marietta/Kennesaw
    i think their are couple stores up in marietta..im not 2 sure.
    Formerly Spyder Man
    Buford, Ga
    I have had remote start on everyone of my cars for the past 10 years, only because i was an installer and knew how to make it work, if there is even the slightest chance it will accidently make it into gear then get started dont do it..
    :boobies:
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Quote Originally Posted by Spyder Man
    just wondering... if the e brake is on and what not... wont the car just stall out?... or will it increase RPM as it sees it dropping?? i have no clue... my friend had one in his prelude on a manual he needed something called a clutch bypass or somethin,
    lol, sounds almost technical...manual transmission cars in the last 15 years or so have had a small switch on the clutch pedal to keep it from starting without the clutch being depressed...a simple jumper wire and a little solder will solve that.
