Thread: Not picking up radio stations.
    Senior Member JASONBALL's Avatar
    columbus GA
    Default Not picking up radio stations.
    I just removed a cd changer from a ford taurus. it had numerous plugs. afterall was removed. I replugged in the main power harness of the system and plugged in what i thought was the antenna in to the box.
    the unit I worked on what in the rear drivers side quarter panel. any info would be great.
    athens
    the antenna should be that big black chord. thicker than others
    Quote Originally Posted by JASONBALL
    BadAssNinjaTrunkMonkey
    in that car the factory tuner box is in the trunk on the left side. you need to make sure that all the plugs are pluged in. The antenna should look like a regular antenna cable. but it may also have to be powered up so check all the plugs.
    may need to get a "patch cable"
    columbus GA
    Quote Originally Posted by tluve69
    explain.
    okay well with the cd changer there were tons of plugs. that went into it. but they were all part of the cd change cable. now there is the antena and the main harness.
    I know that when I worded on my sisters probe I had to get an amp bypass kit basically a "patch cable" which completed the circuit and everything was fine. without it everything powered up and some speakers worked but others didnt so just taking a shot that maybe you are having the same kind of symptoms if you have any un-conected wires/cables...
