Results 1 to 25 of 25
Thread: Shaky at 55-65mph on acceleration
    Apr 2003
    Default Shaky at 55-65mph on acceleration
    my DD, 1994 Accord with H22 swap, recently start to shake (violently) from the speed of 55-65mph on acceleration. It became more apparrent since I hit the pot hole past weekend on the Passenger side.
    I thought it's the wheels, so I changed both front wheels to my spare 17" sets, and still the same thing. I've looked at the suspension components, shocks, springs, tie rods, axles, etc. and can't tell what's going on.
    I thought it'd blow the shocks from the passenger side, but I paid careful attention this morning and seems like the Whole front end of the car is shaky, not just the passenger side.
    Funny thing is it only happen from that speed range, and when I'm on accelleration only, regardless of what gear I'm on.
    Any idea of what could be the problem?
    thx a lot
    Quote Originally Posted by ATK_Designs
    thx a lot
    Most definitely unicorns, maybe even gremlins.
    Does the steering wheel shake? Does it shake any other time when you apply the brakes? Is the car properly aligned? Checked the wheel bearings? (jack the car up and while holding the tire at 9 o'clock and 3 o'clock push and pull it side to side to see if it's loose)
    Apr 2003
    lol...thanks for the response..the steering wheel shake. The car was aligned about 2 months ago. I checked the wheel bearings and they seems okay. I'll have someone drive the car so I can take a look at it from outside to see if there's something funny with the alignment.
    Marietta, GA
    My integra did the same thing, but eventually it got worse. I turned out to be my intermediate shaft. I hit a pot hole too, and the bearing got bent, causing the bearing to rotate eliptically. As I kept driving on it it eventually got worse and worse. you can raise the car up and have someone drive it on the lift. you will be able to see if the bearing isn't spinning right.
    Love Life
    Alpharetta
    Just jack up the front and, with hands holding opposite sides, shake the tire in and out and, with hands on top and bottom, in and out. If there is play both times, then you need to replace the hub bearing.
    banned mother fucker
    far away
    i know when my car did that it was the tires, the belts were seperating and it caused to shake.
    Apr 2003
    thanks guys, I'll have it look at my friend's shop tomorrow.
    the hub i'm guessing
    athens
    go get em balanced.....(wheels)
    pretty sure that could help.
    have you lowered the car at all?
    Apr 2003
    update, didn't have time much to tell yesterday, but I had someone looked at it when I was driving and they confirmed that it spins "elliptically", not rounded.
    I aligned my car as well, didn't help.
    So I guess that's the issue. So is it time to do rotor over hub conversion?
    superduper LLLLLLLLL
    maybe axle/shaft combination is not perfect
    athens
    this is a good bet too. chek axles.
    Quote Originally Posted by AnclyT
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    Sounds like the axle is bent. Any humming from the bearing?
    And from underneath, very unlikely that you'd be able to spot a bent axle on a drivable car.
    Representing VWs.
    Honda Fail
    Columbus
    check the lugs. it happend to me and my wheel almost fell off..
    No sig ATM
    Apr 2003
    Please elaborate, are you refering to it's not matching when the swap was done or it's "not connected / misaligned" right after I hit the pot hole?
    Apr 2003
    Pavlo - I checked the axle, but will do so again
    vngig - I checked that, they're okay.
    C.r.E.a.M MistaCee's Avatar
    Work
    Wheel bearings? but I really think it can be bent axles.
    Apr 2003
    I had my friend drove my car and I looked at it, it wasn't that bouncy.
    1 Thing to note is that it's shaky when it's on throttled from 55-65. Otherwise, it's okay.
    I think it's either the CV join or the part of the axle that messed up. If it's the bearing/hub issue, it should happen through out the speed, not only when we stepped on the gas at that certain speed.
    Marietta, GA
    I still say you need an intermediate shaft.....
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    thx a lot
    It sounds like the lower control arm bushings. Check the inner and outer ones.
    N/A>>><<<BOOST
    PRO desi
    In my car 'round town
    drive shaft?
    Apr 2003
    RUFFIAN - I checked the bushings, they're fine.
    lilmanx01 - I haven't checked it carefully yet. Will do so this weekend.
    **NOTE: Weird thing is that all this vibration causing the car to be shaky, but it still drive straight.
    283.5°.516&quot;(13.11mm) DirtyMechanic's Avatar
    Alpharetta, Ga
    its called the tire balance. there are 1st 2nd and 3rd order vibrations that occurs. and could be at theat 55-65 window.
    The G Spot Hero
    Apr 2003
    Thanks Mike, the wheels are balanced. This is on all my sets of wheels, not 1.
    I found the problem. It's the swaybar endlink bushings. They're busted. I replaced them today and the vibration is gone.
    Thanks to those who helped.
    Alpharetta, Ga
    ive never seen a sway bar being disconnected cause a vib. must be some weak as bushing for the rest of the suspension that it needs a sway bar to keep it from vibrating. lol
    The G Spot Hero
