Results 1 to 32 of 32
Thread: Whining Noise from B18B1
    NW, GA
    Default Whining Noise from B18B1
    ok i have a B18B in my CRX. When the engine warms up i hear a whining noise. I originally thought it was the alternator. However on further investigation it isnt. When i pull the dipstick out the whining stops. Put the dipstick back in, more whinig. So i thought maybe the dipstick was hitting something so i tried just plugging the hole. Still whines. I have no clue what this is, does anyone have any ideas?
    All bark, no bite.
    It's probably whining because it doesn't have VTEC.
    warner robins
    maybe crank case pressure getting past the seal on the dipstick
    JJSPEC.COM
    Hwy 315
    Quote Originally Posted by d16_turbo
    bingo
    -replace your PCV valve and i bet you fix the issue
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    NW, GA
    and how hard is it to replace the PCV valve
    Hwy 315
    depends on which year B18B1 you're talking about really, either of which has minimal skill/time involved.
    90-97 = ten minutes - (on intake manifold, underneath fuel rail)
    98-01 = two seconds - (sitting right on top of the valve cover)
    locate your haynes manual, and get started
    It is easy to learn this tasking young padowan
    -jonathan
    [/URL]
    NW, GA
    out of a 96 integra..so the first one... how much will this cost me?
    Hwy 315
    less than ten bucks; easy fix bro.
    -jonathan
    [/URL]
    NW, GA
    ok thanks i appreciate it
    NW, GA
    so whats it look like, and is it goin to hurt anything if i drive it until i get a new one saturday
    Hwy 315
    my guess would say that you'll be alright driving it until saturday (use your common sense)
    it's a little piece of plastic that connects to a rubber hose. Consult your haynes manual bro. Otherwise, just go to the parts store, ask for the PCV valve (they'll give you the right part) and then locate that same piece on your manifold.
    -jonathan
    [/URL]
    NW, GA
    pretty sure i found it
    Ellenwood
    Quote Originally Posted by iloveboost
    haha i would whine to if i didnt have vteC... HAHA
    NW, GA
    tried to find the pcv valve today and couldnt find it, because alot of the vaccum lines under the fuel rail are capped off.. any ideas?
    Hwy 315
    Quote Originally Posted by tlh89
    yes i have an idea, and it's apparant you haven't tried it (i believe I've mentioned it twice now)
    READ THE FREAKING HAYNES MANUAL - it has picures and everything -
    it's not that hard bro
    -jonathan
    [/URL]
    Southside
    bwhahahahahahaha
    Quote Originally Posted by kainkauz
    LMFAO
    But back on subject it's an easy fix like se7en said
    banned mother fucker
    far away
    this is what it looks like
    Dalton, Ga
    yea ive already bought the part and a haynes manual..still couldnt find it??
    turbo lagg = the few seconds where the other guy thinks he is winning!
    NW, GA
    sorry.. that was me ^^^ my buddy left his account logged in
    Hwy 315
    after all that has been said in these postings already, if you still can't find it bro, then i don't know what to tell you.
    *unless there isn't one installed - in which case, you may be "chasing a ghost" looking for it. Take a close up picture of your manifold and I'll circle where it's supposed to be for you. lol
    this is insane
    -jonathan
    [/URL]
    NW, GA
    its a blox intake manifold.. ill go get a pic real quick
    NW, GA
    NW, GA
    and what can i do if there isnt one installed?
    Banned LS2ner's Avatar
    The Face
    burn ur car. j/k. sell ur blox ITM and get an OEM one.
    It's all about JDM.
    CA to GA
    I was going to post a diagram of where the PCV valve located but, you said you have an after mark. manifold. If you still want it, i'll upload it. just pm me.
    NW, GA
    ttt
    Hwy 315
    there you go bro
    -jonathan
    Attached Thumbnails Attached Thumbnails -161jj7k-jpg
    [/URL]
    Columbus, OH
    Its not hard. Fukin pull it out with some pliers (if its the original its gonna be a PAIN without them and its way past due) just pull it out and push the new one back in.
    Its on the top of ur motor by the way.
    Attached Thumbnails Attached Thumbnails -img00217-jpg   -img00218-jpg
    i was about to say the same.. lmao
    /Oo ___A___ oO\
    |=_/_______\_=|
    jupiter
    wow....just wow!!!
    YEAH! bRiAnMcIvIcS's Avatar
    Instead of buying a new one, can't you just spray out the old pcv valve with carb cleaner?
    90 Si w/vtec 90SiHatch's Avatar
    White Co, GA
    it can also be your alternator making the noise, loosen up your alternator and take the belt off and start the engine and see if it still makes the noise. if it doesn't it could just be the bearings in the alternator, i had one do this and it never went out on me.
    Isaac-
