- is this good or bad...
wow thats deff not a good thing just throw some sealant on it and it should be fine id think since its just a waterjacket
but just out of curiosity, why didnt you stop when you noticed that it was gettin harder to turn?
- Rep Power
- 20
Not totally sure but I would say no. Just because its supposed to be enclosed but it might be fine if nothing major gets on it or if it releases any dirt or metal chips you know
i bought the motor and was cleaning it and i saw it like that already...
you can use a sealer or jb weld for it, but it is just a coolant jacket so it wouldn't be that bad...go to an auto parts store and ask them about it
- Rep Power
- 21
i think it will be ok at least it did go all the way to the pistons
once the coolant system has pressure on it you will have a leak...if that block was mine i would toss it in the trash. totally worthless
- Rep Power
- 21
Have somebody Tig weld the whole from the inside, JB weld will crack over time from hot/cold cycles and pressure.
- You may not post replies
- You may not edit your posts
Forum Rules
