Results 1 to 11 of 11
Thread: distributor clicking noise and Engine Light on?
    It's all about JDM.
    CA to GA
    Default distributor clicking noise and Engine Light on?
    I notice that my distributor makes click noise, and wondering if this is an issue? And my engine light keeps coming on everytime I reset ECU, showing that there is misfire on #1 and 2 piston???? I already changed new distributor cap, spark plugs, and just redid timing belt?? but now I can't figure anything else, need help people....
    Certified Gearhead JDMef88's Avatar
    Gainsville, GA
    make shure your plug wires are in the correct order, mine did that, but my injectors on 3, and 4 were not screwed in all the way and i had to tighten them...
    It's all about JDM.
    CA to GA
    thanks JDMeg88 for your input...hope youre right.
    The poorest rich guy myyellowspec's Avatar
    Dallas, Ga
    It is more than likely the bearings in your dizzy. Happened to both mine and my wifes Integra's. Had to get new ones each time.
    89 EE Wagon
    Certified Gearhead ATLem1's Avatar
    west
    Quote Originally Posted by myyellowspec
    ^^^^ word, i agree with him.. same thing happened to my first gen b16. take the dizzy off and just spin the key/ shaft on it.. if you hear it then or if you feel resistance.. its more than likely the bearing.. and it could sieze so take care of that.
    It's all about JDM.
    CA to GA
    The noise seems like it's coming from the rotor hitting the cap. Yet again, that's what I think it is, but can someone give me a better diagram or explanation what the bearings look like or located on the dizzy...Thanks.
    west
    did you figure this out yet? just curious.
    Certified Gearhead civicracer5000's Avatar
    atlanta
    well the distribuitor had some kind of sensors and if one of the sensors fail it will cause you to have misfire and the only way to fix that is by replacing the dist.
    It's all about JDM.
    CA to GA
    Quote Originally Posted by ATLem1
    Naw, didn't figure it out yet. Can you help in anyway?
    It's all about JDM.
    CA to GA
    Quote Originally Posted by civicracer5000
    By the way I already fixed the CEL (check engine light) for the misfire code, it was my spark plug wires (the connectors on the wire were bent and weren't touching the spark plugs...stupid me). But the clicking noise is still there on the dizzy??? Is that how supposed to sound like when I put a new dizzy cap, am i suppose to let it break in first?
    west
    Quote Originally Posted by gsrteg
    i already tried.. i honestly believe its the bearing. keep us posted
