- speaker problem
- Rep Power
- 22
sounds like you blew you rear outputs on the deck, may either have to run an external amp, repair the headunit, or buy a new one if so. hook an ohm meter up to the outputs from the deck and see if you get anything
how would i repair it? and how would it blow?
try a different harness, could be a short in the wires. or like tluve69 said, deck could be bad. another thing to check would be make sure there are no bare wires. if the positive touches negative, you wont get any sound.
ill try the harness... first its the cheapest...lol
- speaker problem
- You may not post replies
- You may not edit your posts
Forum Rules
