Results 1 to 10 of 10
Thread: B16A Swap what exhaust header?
    Unknown Siner9's Avatar
    USA
    Default B16A Swap what exhaust header?
    Hello everyone this is my very first post. I know this question has been asked before but I would like to know what exhaust header did you guys use on your JDM OBD0 B16a swap?
    My car is a 1989 Honda Civic Hatch.
    Lowerd 2" all around with camber kits front and rear.
    Current header is DC Sports with DC sports catback exhaust.
    Im a little worried about ground clearance on the header down pipe.
    Once I finish the paint and swap on the car I will post pictures with a full spec list. Also plan to post time slips for Road Course and Drag. Turbo to come soon after install but want to see how it runs N/A first.
    Thanks for reading! Holla Back!
    USA
    Default Bump
    Bump
    the clearance would prob be as low as mines, my ef is droped 2 in on the front and my b16 downpipe sits about 3 in off the ground....scrapes....im looking to getting coilovers to raise it up. unless u get lowering springs like 1.5 in drop
    southside ATL
    what type of headers you have...like 4-1 or 4-2-1...because 4-1 is going to scrape more than the other..cuz it sits lower
    BABIES "R" US crew
    USA
    Default DC Sports Del Sol Exhaust Header?
    I was looking at a DC Sports 4-1 header 1996 Del Sol... do you guys think this will work or would I have to get it cut and welded to make it clear the ground and connect to my cat?
    Your moms house
    You also should be running the two o2 sensors on a b16a. If you are doing it that way you will have to get 2 o2 bungs welded in the delsol header, Or you could wire them together at the ecu and run the obd1 design.
    I am running the Itr 4-1 on my crx that is slammed, but I have the shield on the bottom.
    paint booth
    i liked my old greddy header better than the dc sport's i had.
    1.5T AnTi-PooN's Avatar
    L'villE
    check out the ef squad section
    USA
    Thanks everyone for the info. I will check out the EF page. I plan to have the ecu chipped and prepaired for Vtech. I will ask them about the O2 senor also.
    Car: Da BabyShoe
    1989 Honda Civic Si
    YEAH! bRiAnMcIvIcS's Avatar
    Quote Originally Posted by Siner9
    VTEC. no h.
