Results 1 to 11 of 11
Thread: h22a into 92 civic cx hatch
    GetItFixItFlipIt Timinater's Avatar
    Default h22a into 92 civic cx hatch
    I need help with the wiring. the h22 has the full harness up to the ecu, the 3 ecu plugins and then the green dash one. but the civic dash plugin is different, also i dont see how the h22 harness will attach to the fuse/relay box. if anyone can help that would be great. call if you can 404 418 2510
    thanks.
    tim
    you need to just use the civic one , and modify it to accomodate the h22. we can do it 678-567-9384,
    is it something i cant do on my own?
    and its already been modified for b-series vtec
    stock EK
    home
    you can do it yourself just extend some wire like alternator, and stuff
    have you done it before?
    You can do it yourself, but some people are not good with wiring, so i recommend taking it somewhere. I have done a few, and its not too bad, just a little time consuming.
    will all the wires be the same colors or is there a post or guide somewhere that can tell me how to do it?
    Im sure there is, but you really just need to look at what you have, lay it out on the engine, and extend from there. You are probably going to have to extend; injectors,iac,iat, add iab if you didnt have a gsr, add knock if it wasnt vtec (or some b20) also extending alternator stuff...etc thats off the top of my head.. im sure there are more, like possibly extending vss,fan switch etc.
    use your b series or d series engine wire harness....make sure you have both harness wire lay out the same and cut and extend and slap it on ur good to go...!
    alright. thanks fo the help everyone. any more would also be greatly appreciated
