Thread: dohc zc what ecu can i use i have a po6 will it work?
    Certified Gearhead 93delsol15's Avatar
    tennessee
    Default dohc zc what ecu can i use i have a po6 will it work?
    i need to know if i swap a dohc zc into my del sol if i can just put it in and go.
    d15b7 fs 300obo has to go soon
    the county
    Quote Originally Posted by 93delsol15
    the p06 i think is for a single cam motor. the fuel ratio will be different and might idle a little funny. but i think it will work. i'd try and run an ls computer if you can get a hold of one.
    Belview Insane Asylum
    Why would you put a ZC in a Del Sol? I am pretty sure that ECU won't work.
    tennessee
    i am putting a zc in because i am low on funds and i am trying to get some decent power and i dont want the limitations of a single cam
    Your moms house
    Lots of my friends run the zc's in their crx'x and use the pm6 si ecu. I know the pg7 88-89 integra ecu is better though. The sohc ecu wont hurt it though. I know that doesn't help much since your car is obd1. Maybe get your ecu chipped with a zc basemap, or try a ls rp4 or p75.
    But you are trying to put an OBD0 engine in an OBD1 car. That's going backwards.
    Your moms house
    they have obd1 zc's
    Quote Originally Posted by 1flysi
    they have obd1 zc's
    Yes they do but I thought they were less HP than the OBD 0 ZCs? It's been a while I can't remember off the top of my head.
    General Tech Hater
    they also have OBD-2 ZCs. or atleast ones with crank angle sensors, identical to a D16Y7.
    tennessee
    the obd 1 has more hp 135-140 instead of 128
    Snellville/Statesboro
    decent power and zc shouldn't be in the same sentence, unless turbo colsely follows
    the numbers are debated, give or take a few, but thats pretty much correct
    UPROOT Photography FTW
    tennessee
    yeah i am boosting it on stock internals for a few months prolly round 7psi until i can get new internals
