Thread: Integra compression help.!??
    95 teggy for parts DaRussian's Avatar
    Question Integra compression help.!??
    Does anybody know the compression that should be in a b18b1 motor? i dont need the ratio, i need the compression in PSI ? does anybody know it? my engine is showing around 150psi in all 4 cylinders and its not running right...
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    Senior Member boosted b's Avatar
    it shouldn't exceed 199 psi or be lower than 135 psi in a b18b1
    Lsu tigers going # 1 again
    Quote Originally Posted by boosted b
    ok thanks, so my compression is good then... because it shows around 150 in all 4 cylinders.
    how is it running
    how is it running
    i think that it must be running rich or something, because when i drive it does not pull at all, has no power. it idles good, but when i rev it up it starts to misfire or something i dont even know
    when was the last time u tuned it up or what kinda gas have u put in it lately
    i didnt tune it, filled up at qt before i didn the swap. i just put it in my hatch like a week ago
    was it running ok before u put it in or u don't know
    i thought it did. it sounded pretty good but the car wasnt drivable so i couldnt check,
    without really lookin at it all i could really do is guess but start with the tune up
    An LS SHOULD somewhere around 175-180 psi. 150 is kinda low.
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
    even though 150 sounds a little low it should run fine with that compression.
