Results 1 to 16 of 16
Thread: Civic auto to manual
    Norcross
    Post Civic auto to manual
    i got a 96 civic ex.. its auto.. and i want it to b manual.. so should i..
    a) get tranny swap with d16 still in it
    b) get tranny n engine swap at the same time
    c) get a new car
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    wiring, shifter and linkage, transmission, pedal assy. etc. etc. a service manual and a lot of patience.
    Who knows?
    San antonio 210
    ur going to spend to much money. Your best bet would be buy a swaped car...
    do you know how to drive a manual?
    if the answer is no do a tranny swap with d16 still in it.
    Augusta Ga
    i have everything u need including a d16 tranny with no problems and all the hardware pm me if interested . ill let everything go for around 350 $ .... all u need is time to do the swap and the know how ... everything is included shift linkage, clutch lines, clutch cylinder , slave cylinder , d16 tranny, and shifter with rubber bushing .
    93 sol Si
    95 sol S
    95 sol Si
    한 국
    d) sell the car and buy a manual
    LAWRENCEVILLE
    its not to bad do it with the engine you have in now you would need a trans,flywheel,clutch set, clutch and brake pedal"ek specific", rear mount trans mount, linkage, clutch mastercyl, clutch line, also a 5 speed ecu. but it can be done. and its really not to bad.
    Hella stock member!
    Augusta Ga
    me n my friend done the swap in like 4 hours .. its not hard ...
    93 sol Si
    95 sol S
    95 sol Si
    Norcross
    koo... thanks i think im goin to gather up some freinds n try n do the **** myself haha.. are any of the engine mounts different? and do i need to do any cutting..? what else should i kno
    Augusta Ga
    you either need a mount kit ... or you need a welder ... u can weld on a tranny mount or you can buy a kit that i think bolts to the frame .... my friend jus welded a motor mount to where the tranny was suppose to go an did it that way ,, but if your concerened about the way it looks .. then buy a mount kit from hasport .
    93 sol Si
    95 sol S
    95 sol Si
    Norcross
    does anyone know the best place to get this done.. and how much it would cost.. does anyone do it on the side for cheaper?!? thanksss
    Warner Robins, GA
    get a different car
    Augusta Ga
    ill do it ... but will be expensive ... theres alot of work .. dont get me wrong ,,,, but its not as hard to do this, than swapping a LHD to RHD .. .. lol EDIT : nvm i forgot im in augusta AKA DISgusta ...... lol
    93 sol Si
    95 sol S
    95 sol Si
    Alpharetta
    dayum man.. make a real poll.. f.uck... just get a new car that stick.. aint no point in spending money to swap in and out shyt when you can get it already available for your ass.. think finacially.. if you cant afford.. get a job or get more money.. if you can afford.. then get another car thats stick or just swap it but the hassle is on you
    1.5T AnTi-PooN's Avatar
    L'villE
    i have a d16 si tranny if you're interested
    95 teggy for parts DaRussian's Avatar
    buy a wrecked one and swap it out, otherwise if ur going to buy everything seperatly its not worth it. i know somebody who did a auto to manual swap in a 1995 accord and he paid 2800, with labor. thats a big rip off. lol (just my opinion)
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
