Results 1 to 3 of 3
Thread: PROBLEM....
    한 국
    Default PROBLEM....
    i just bought a itr cluster and when it in my car the fuel meter doesnt work and when i put my stock cluster everything works. nothing is wrong with the cluster i just dont kno why the fuel meter doesnt know. anybody kno?
    Super Dave Z U L8R's Avatar
    Roswell
    the different gauge cluster either has a bad fuel level gauge in it, or that cluster uses a different value for reading the fuel level from the fuel level sending unit.
    if you know for a fact that the fuel gauge is good in that itr cluster (by putting it in an itr and seeing if it works) then you may wanna try double checking wiring/connections or just put an itr fuel level sending unit in your car.
    gl,
    Dave
    same value, just a bad gauge its very easy to fix, take your working gauge out of the cluster an install it on your itr one, but use the overlay on the intr, I have done this many times,
