Thread: LS SWAP oxygen sensor problem
    95 teggy for parts DaRussian's Avatar
    Default LS SWAP oxygen sensor problem
    ok i just swapped an ls into my hatch and my check engine light came on. i checked the code and its
    CODE: 1 (Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor)
    anybody know how can i fix it?
    tawksick. toxxxic's Avatar
    Roswell
    replace the o2 sensor ??
    anybody?
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    GetItFixItFlipIt Timinater's Avatar
    did you try messing with the o2 sensor or any of its wires? replace the sensor or if you have a chipped ecu get it disabled when you tune the car.
    Did you swap the sensor to a 4 wire sensor when you did the swap? The civic has a 2 wire o2 sensor and the integra has a 4 wire. That's most likely why you are throwing the code. I would do that first and then your car should run fine.
    Straight up JDM!
    Go to honda-tech.com and did you do o2 sensor conversion? what blown_ss (above post) said...
