Results 1 to 6 of 6
Thread: LS SWAP oxygen sensor problem
    Default LS SWAP oxygen sensor problem
    ok i just swapped an ls into my hatch and my check engine light came on. i checked the code and its
    CODE: 1 (Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor)
    anybody know how can i fix it?
    anybody?
    tawksick. toxxxic's Avatar
    Roswell
    replace the o2 sensor ??
    GetItFixItFlipIt Timinater's Avatar
    did you try messing with the o2 sensor or any of its wires? replace the sensor or if you have a chipped ecu get it disabled when you tune the car.
    Did you swap the sensor to a 4 wire sensor when you did the swap? The civic has a 2 wire o2 sensor and the integra has a 4 wire. That's most likely why you are throwing the code. I would do that first and then your car should run fine.
    Straight up JDM!
    Go to honda-tech.com and did you do o2 sensor conversion? what blown_ss (above post) said...
