Results 1 to 25 of 25
Thread: LS SWAP problem >> TOO SLOW lol
    95 teggy for parts DaRussian's Avatar
    Default LS SWAP problem >> TOO SLOW lol
    ok i dropped an LS in my hatch today, and it is extremely slow, it seems like it doesnt have no tourqe at all,
    The timing and the ignition seems to be fine, but when the engine is working to me it seems like its shaking a lil bit more then it should.
    anybody know what the problem could be?
    I cleaned the injectors,
    the check engine light comes on,
    93 Civic Hatch, LS SWAP gsr wheels, new PAINT 12k HID, 5spd, CLEAN!! Perfect shape <<< here is the link of the car, its for sale by the way...
    What kind of hatch?
    Quote Originally Posted by GSRteg®
    What kind of hatch?
    eg, 1992 civic vx
    here is the link
    LAWRENCEVILLE
    what is the check engine light on for? what ecu and wireing harness are you useing?
    Hella stock member!
    Quote Originally Posted by silversol
    Integra ECU and integra engine harness
    Have you cheked to see what the code is?
    no, how can i? the engine is off of a 95 teggy
    Quote Originally Posted by DaRussian
    It's a Honda? It's supposed to be slow. Later, QD.
    BLow me
    I afraid that won't be possible. But your response confuses me. I thought you might be a dude, but you're posting like a *****. Then you say to "blow" you, thus making it seem that you are in fact a dude. SO which is it....a dude or a *****? I'll take the latter for $500, Alex. Later, QD.
    what are u talking about?
    Never mind. You lose. Good luck with your race car. Later, QD.
    Honda civic hatch has a plug under the glove box ill see if I can get you a link to help you better.
    Here is the link to the site were you can see how to do it and see whats wrong with it.
    http://www.geocities.com/jgennoy/ecu/ecu.html
    LOL at QD ,, he seen this happen lots, check to make sure your fuel injectors are plugged correctly, seen ppl connect them an not be snuggled up tight lol at my words, or its miss firing, like firing order is wrong, its 1-3-4-2 timing belt is 1 an distr plug is 4 check that!
    What he said ^^^^
    the plug is little 2 pin connector that is blue, an its behind glove box right lower side , skinny not the fat one, an you jump it with a paper clip an turn key on to lights light up an count check engine light flashs, 1 slow blimk is 10 1 fast blink is 1 so if it blinks 1 slow blink an 4 fast blinks the code is 14 ,, got it GOOD
    an if it doesnt blink then your paper clip needs adjusting, play an wiggle it until it starts blinking then start over , by turning the key off wait few seconds, then turn it back on an start counting
    hope this helps if not pm ill help threw the phone !
    clayton county
    get a gsr tranny?
    I give out reps....
    get a gsr tranny?
    i got a ls tranny, thats not the problem its like maybe a little bit faster then the d15 that i had in it...
    Did you check the injectors and the ECU codes I gave you the site????
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    sounds like it's skipping if it is shaking. did you replace the spark plugs, wires, check your rotor button and dist. cap before putting the motor in?
    oh wait... i forgot nobody does the maintenance items anymore.
    Who knows?
    alright thanks dude, i got it figured out it was code 43 which is fuel problem but i got that fixed.
    140 on one wheel
    columbus, ga
    so does it run strong now?
    gwinnett
    ROFLMAO!
