Results 1 to 5 of 5
Thread: Turbo GSR
    Duluth, GA
    Default Turbo GSR
    I used to work at an engine shop so I know a lot about n/a motor stuff but when it comes to boost i'm kinda in the dark. I wanna turbo my gsr but i don't want to do it until I at least know how everything works. Anyone know where I can read up on turbo stuff?
    MEGATRON 112480's Avatar
    Mobile,AL
    What is your budget??? What are your HP goals??? These two questions need to be answered first.
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    Duluth, GA
    i'd say around $700 maybe more if it's necessary, i'd like to make anywhere around 300whp
    DC5-R
    Gwinett
    Quote Originally Posted by mrhan44
    $700 and 300whp, keep dreaming.
    For maybe about $1k or more you can obtain a decent kit, and make decent power with them. Is it going to be daily driven? ac/ps?
    ebay intercooler kit - $150-200
    cast iron manifold (one of the cheapest and strongest) - $100-150
    Injectors - can find dsm as cheap as $100 for 450cc but must be used with a resistor box.
    Wastegate - not needed if the turbo you choose is internal wastegated, but if not then look to spend about $150+ for a decent one. Don't go with that ebay crap, you will have mad boost spikes.
    BOV - ebay will do but look to spend around $150+ for a decent one
    Misc. fittings and oil line - $100 or so
    FMU/Missing link/Chipped ecu - one of these options must be chosen for your car to be able to run. Ranges from $20-150. If chipped ecu is the choice, expect to spend about 2-3 hours of tuning for about $140 an hour.
    Downpipe - can pick one up for as cheap as $75
    Turbo - for your build, a t3/t4 should do, which can run you about $250 used to $700 depending on size and trim. Ebay is your friend.
    this is the cheapest that I could come up with, and most of the parts can be found on ebay. Then again you could just buy a complete kit and be done with it but I see that you're on a budget so hope that helps.
