Results 1 to 29 of 29
Thread: NEED HELP BEFORE SATURDAY NIGHT! 1/05/08
    my momma's house
    Default NEED HELP BEFORE SATURDAY NIGHT! 1/05/08
    I need help from a trustworthy EJ-EG Squad affiliate, who knows how to set timing.
    I'm located in the lawrenceville/Snellville area, so if ANYONE can help me really fast, before I grow impatient and try to do it myself and blow my motor up, I would REALLY appreciate it.
    REPS FOR HELPIN' A BROTHA OUT!!!
    Trend settin'
    Southside
    I could help guide you through it, if you have factory cam(s). Is it SOHC or DOHC?
    San antonio 210
    ^^ he would be ur man for timing...
    95 Ecllipse GST
    clarkesville,ga
    Damn all you guys get on really really ****in early lol..
    1999 MITSUBISHI ECLIPSE GSX
    WORLDS FASTEST MODIFIED 4 CYLINDER
    OWNER: BRENT RAU
    4G63 YUP
    1400 HP
    2200 LBS
    11,000 RPM
    86 PSI OF BOOST
    MAGNUS MOTORSPORTS
    THAT IS 350 HP PER CYLINDER
    AND YES ITS A MITSUBISHI ECLIPSE
    1/4 MILE IN 6.97 SECONDS
    BRENT RAU'S MESSAGE TO OTHER DSM'RS:
    NEVER GIVE UP
    Quote Originally Posted by dcshoeco
    That's what we do.
    San antonio 210
    **** im at work, i have nothing better to do...
    my momma's house
    I've got stock DOHC.
    404.384.0269 hit me up.
    Trend settin'
    my momma's house
    Cum'mon EG-EJ Squad! Help me out.
    Trend settin'
    Southside
    Quote Originally Posted by TheChosenOne
    Sorry about that man. I got caught up with help JDMJAYDC2 with getting a motor from way out in bumble fawk I think on 985 (I can't remember I was tired) and then after that I was helping Korilee with pulling his motor out and didn't have a way to check on IA, did you ever get help with it?
    San antonio 210
    i know nothing about swaps.. or timing
    my momma's house
    We fixed the timing, and it runs WAY BETTER NOW.
    The intake cam was retarded by 2 degrees. We got it all set right, but I tightend the tensioner really tight, but the belt is still kinda loose.
    If anyone can help me, I still need a little bit of knowledge. I just dont want my belt to snap.
    Trend settin'
    Southside
    It's a tooth off or so, because the tensioner pulls it all into place. It's suppose to have a lil slack between the Intake Cam and water pump, should be tighter from crank to exhaust cam.
    Does it look like it's just flapping around when you cut it on?
    Project DX
    Quote Originally Posted by JDM_EK4
    The belt is tight were the exhaust cam is but its lose in the back were the intake cam is so I guess the timing on the intake cam is still off like u said n the car is still sluggish. But ima get with him tonite n mess with it to c if that's it..
    DOHC NO-TEC
    Project DX
    Does it look like it's just flapping around when you cut it on? [/QUOTE]
    Yea his belt flaps worse than rosie odonalds breast.. N the tensioner is as tight as it can b
    DOHC NO-TEC
    Southside
    Quote Originally Posted by itz a jew
    Using stock Cam Gears of After-Market?
    Project DX
    Stock
    DOHC NO-TEC
    Southside
    Yea it's a tooth of or so. Ok and in between the In. and Ex. shouldn't be any slack at all. If you can or even want to explain how it was installed so I can determine what can be done to fix it?
    Project DX
    there is no slack there but in the back were the exhaust cam is.. idk how it was put in he wouyld have to tell u that but im just explaining how i saw it last night.. but thanks for the helpp reppssss!!! but im sure when he gets on here he can explain a lil better since he was the one who put it on
    DOHC NO-TEC
    Southside
    Ok no problem, anytime........whenever I'm available lol
    Project DX
    But ima help him advance the tooth one more or half n c if that's n c if helps n I wil let u kno
    DOHC NO-TEC
    Southside
    isn't his name Jordan.
    Post up Jordan
    Project DX
    Post up Jordan
    Yea his name is jordan but I think he is working.. Basically from wat he told me was he pulled the belt off the cam gears n adjustated the exhaust cam
    DOHC NO-TEC
    Project DX
    So he didn't take it all the way off just moved it enuf to adjust the gear.. If this helps any
    DOHC NO-TEC
    Southside
    Wow..............................
    Pull the belt completely off the cams, water pump etc. Start with it on the crank of course and then with the right side of the belt slide it a little bit on the tensioner then with the left side pull up to the exhaust cam with little to no slack, then pull over to Intake cam, now you go back to the tensioner and pull it to the water pump, you should see and feel a difference now all you have to do it tighten it down and it should be good
    Project DX
    Great! I sure he will b glad to c this lol
    DOHC NO-TEC
    my momma's house
    Thanks for the relpys!
    I'm typing this on my sidekick, so reps when I get home!
    This is what we did:
    1. Took of the valve cover and removed the belt of both cams.
    2. Set the crank to TDC.
    3. Lined up the cams to what seemed to be correct timing. Vounge did my timing on my rex like a week ago, so I just did what he showed me, which was to line the two tick marks up inbetweent the cams. He also told me that the outside cam tick mark should be flush with the top of the head.
    4. Lined up all four tick marks with a string.
    5. Loosened the tensioner and slid the belt back on. It seemed like the cams wanted to go back to the tretared timing everytime we tried to slide the belt back on so one of us had to hold them in place while the other slide the belt back on.
    6. We tightened the tensioner to the max, but there is still a slight bit of slack on the exhaust side. The intake side seems to be aight.
    To me, I'm almost certain the timing is correct, but if it is off, its only by 1 degree. The car runs a lot better, but its still not as quick as it should be with the setup I have.
    Jew Boy and I are gunna take another crack at it again, so hopefully ill be squared away by mid-week.
    Trend settin'
    Project DX
    Jordan.. Did u fix it yet? If not call me when u get off work so we can do it
    DOHC NO-TEC
    NITROUS JUNKIE
    home
    matt lmk if ya need help
    Project DX
    Quote Originally Posted by EJ6
    Ok
    DOHC NO-TEC
