Results 1 to 11 of 11
Thread: Did swap and half shaft wont bolt....help
    Rice Rice Vtec
    Default Did swap and half shaft wont bolt....help
    like the title stated!!!
    yes, my cousins and i did a 95 LS swap for his 93 si hatch and got everything going until the half shaft didnt bolt up to the to the block.....so we went and bought a 2nd half shaft thinking that its the half shaft so thats why it didnt bolt up but then happens to turn out just like the 1st one we had!!!so as of now thats the only thing that is wrong with the car, everything started up and no check engine light or nothin at all....
    well, i have a couple question to ask???
    what can it be???
    can it be the B16 tranny we using for it???
    can it be that the motor or anything is warp'd???
    95 Civic EX-Traded
    93 Civic CX -Sold
    93 Nissan Altim-Sold
    95 Civic CX- RIGHT NOW!
    your moms house
    are you sure it's going into the trans all the way thats the only thing that would keep it from bolting up all b series halfshafts have the same bolt pattern so it should fit unless it's not a b series
    in a paint booth
    Quote Originally Posted by all-mota
    Same as he said but More than likely its not in all the way make sure it is sittin flush with the axle seal
    known as Charles
    Are you sure it's not an auto half shaft. There is a difference in the automatics and the 5spds. They look the same but the mounting flange is positioned in little different. Good luck.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Rice Rice Vtec
    for all the other info from the other guys, everything seems fine and fitted pretty well......it goes in all the way but then it just wont come up all the way to be bolted on but then thats all we know as of now and thats the only problem we got with the swap.....
    this is the 1st time it ever happen to me doing a swap
    Quote Originally Posted by Main Stream
    95 Civic EX-Traded
    93 Civic CX -Sold
    I have seen weere someone tried to use the auto one and it didn't work. I would get a stick shift one and see if it works
    Better watch your back...before you get the NINJA SLAP
    Rice Rice Vtec
    ill try it the other way around then
    95 Civic EX-Traded
    93 Civic CX -Sold
    2slow4u
    P-town
    ttt bump anyone else
    workin on it!
    Im just talking out loud here:
    90-93 integra halfshafts are DIFFERENT than 94-01 Half shafts
    One has a male end, one is female
    Auto Halfshafts are different than MANUAL halfshafts
    Axle seals are different between CABLE and HYDRO Transmissions
    Now, if you used an AUTO BLOCK, wouldnt you have to use the AUTO Halfshaft? Since the halfshaft bolts to the block, if the motor was originally an auto, the manual shft wouldnt fit correct?
    What you need to do is take a picture of that halfshaft you HAVE and where its not bolting up so we can see it.
    2slow4u
    P-town
    when open
    when closed
    sorry for all the pics but u get the idea....
    workin on it!
    Banned CANCER's Avatar
    In your body
    He has an auto half shaft, the blocks are the same between the auto and manual, the halfshafts are differant. The position of the diff is a little further back on an auto car, thus the reason that it doesnt sit flush to his engine. Buy a 5-speed shaft that will fix the problem.
