Results 1 to 11 of 11
Thread: blow down tube
    about this far.
    Default blow down tube
    what is the point of having a blow down tube when you are using N²o??
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Duluth, G-nett
    you got to have that if you are drag racing. safety precaution.
    about this far.
    i know that.. but what dose it do... and how dose it work?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Duluth, G-nett
    i really don know how it works, but it de-pressurizes the tank if you happen to get in a wreck or easy access to de-pressurizing the tank if the car catches on fire.
    about this far.
    ooo got ya... so it worth the money to get one
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    so u dont burn to the ground like the black C6Z06...
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Flowery Branch
    blowdown tube is simply a bypass, if your shooting nitrous and something goes wrong it acts like a check valve and just blows it to atmosphere as opposed to the motor etc
    Johns Creek
    A blow down tube is required on any car running on a NHRA-certified track if the nitrous tank is located in the passenger compartment (i.e. - not isolated in the trunk).
    The reason why is simple. Automotive nitrous is not like medical grade nitrous. If has sulfer dioxide in it, and will make your lungs feel like they are burning if you breathe it. Basically, on all bottles there is a pressure relief valve - usually set to about 3000psi. If the tank build too much pressure, the relief valve will open, letting the nitrous out (so the bottle doesn't explode from the pressure). The blow down tube is attached over the valve and routes the nitrous out of the passenger compartment usually to the underside of the car. If you did not have the tube, the nitrous would be release into the compartment, and you would probably find that it would be difficult to focus upon your driving.
    Quote Originally Posted by David88vert
    well said
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    DOTCOM SpeedDreamz's Avatar
    alabama
    Ask Sam Mahdavi what it is for. A couple years ago in St. Louis it was about 150 degrees and his popoff blew on a nitrous bottle, it busted his blowdown and shattered his back glass. I was pit'd next to him and it scared the crap out of me.
    Mobile Electronics and Performance
    Tuscaloosa, Alabama
    In-ground Dynojet
    Jan 2003
    Quote Originally Posted by SpeedDreamz
    Exactly. His back window was shattered and it sounded like a shot went off. It's attached to the main valve as a safety release when the pressure gets too high. Sam's did because of the heat coming thru the untinted rear window. If you have the nitrous in the trunk by itself and you don't use a heater on it, you should be fine for street type use. The blow down is a must in the race car where there is nothing between the bottle and the driver, besides the fact that it's a race requirement.
