Thread: Half boost, help!
    Intugly tybalt6691's Avatar
    Default Half boost, help!
    Help! I need to check my vacume lines I am only getting half boost. I have yet to do anything but lay a coat of wax on the the car and I only get .5bar boost this morning on my way to work.
    Give me some more **** to check while im under the hood. I dont think its the "pill" as I have yet to do anything with the vacume lines or waste gate.
    MAY CAUSE CANCER Psycho's Avatar
    Standing Right Behind You
    If you're only hitting 7 psi, you're probably running off the wastegate. Check your boost control solenoid to make sure it isn't all ****ulated and what not. Also, check to see that the recirculator valve isn't sticking open.
    Is the car reflashed? You may be in the low boost map. To alternate maps, turn the key to the "on" position, press the gas pedal all the way down, and simultaneously press the rear-window defrost button (make sure the gas pedal is pressed all the way down and be sure to let off the gas before switching the defrost back off). You can actually do this method while the car is running. I use to do it while driving down the street occasionally if I wanted to save gas on the highway.
    Do you hear a noise, which sounds similar to baseball cards in in the spokes of a bicycle, while the car is running? If so, you may have an exhaust leak on the up-pipe. I use to have a problem where the EGT sensor would back it's self out of its bung. If you feel the up-pipe (exhaust pipe that leads to the turbo from the manifold) you will feel the EGT sensor, which is located about an inch beneath the turbo. Make sure it's nice and tight or you'll be losing much of the exhaust you need to spool your turbo.
    Do you hear a loud whining sound when the turbo is spooling? Check the y-pipe to make sure it's clamped nice and tight on both the turbo and the intercooler. Make sure it isn't cracked or worn.
    Also, make sure the rubber connector that connects the intercooler to the throttle body is tightly clamped.
    If all else fails... sell it and buy an Evo.
    I am going to take her to Mike at RPM on Saturday to
    Change out the gear oil to mobil1 75w90
    Change out the rear diff to mobil 1 75w90
    Bleed out the clutch line
    Check for the boost leak
    and do an overall checkup on her. I hope to have it running alot better then. I have heard good things about chaning out to the mobil1. I dont like how the tranny currently shifts and have put some serious thought to an RA gearset down the road.
    what year WRX?
    Rock the 40oz GTScoob's Avatar
    GA Tech
    I wouldnt run Mobil 1 gear oil. Just run the OEM stuff, or the gear oil cocktail if you feel like spending $60 on tranny fluid.
    Check what size restrictor pill you have in your wastegate line. If its the wrong size it'll cut down your boost, also make sure everything is connected to the boost control solenoid (under the cover near the passenger side strut tower). If everything mechanically looks good you might just want to reset the ECU.
    02 WRX Sport Wagon
