Results 1 to 11 of 11
Thread: Car Problems After Swap
    Vinings, GA
    Default Car Problems After Swap
    I just swapped my my 89 240 over to a 95 ka24de and its running like crap. The engine is fine and when it idles it runs perfectly. The car will only idle with the MAF unplugged and it wont rev over 3K with out it. As soon as you plug the MAF in it starts to sputter then dies. We get a new MAF which fixed it running rich but it still wont idle when its plugged in. When the MAF is in its like you have to keep fighting with the throttle to keep it alive. Also the Engine keeps over heating. We replaced the thermostat and refilled the coolant but it still over heats.
    If you got any recommendations don't hesitate to post, thanks.
    gwinnett
    About the starting system, and idling problems: Is that it, what kind of smoke is coming out of the exhaust?
    Overheating: Does your fan for the radiatior work?
    Duluth, GA
    check the maf, if you have bad maf car will die.
    Vinings, GA
    Quote Originally Posted by 13b_soldier
    Overheating: Does your fan for the radiator work?
    Theres white smoke coming out when its cold like normal, then some black smoke when its warm. I just sea foamed it so I know its still getting rid of the carbon. when you full throttle it the car will just bog and take a while to rev up.
    Heating, there is only the fan connected to the crank running. I went out today and put some more coolant in it and it ran way better temperature wise.
    Vinings, GA
    Quote Originally Posted by cdhtang
    I just replaced the MAF with a different one so thats not it. We think the ECU might be bad so I'm going to get another one and see what that does.
    gwinnett
    So on the overheating, it was low on coolant ?
    Smart Went Crazy skillzilla's Avatar
    Roswell
    Try resetting the ecu with the new mafs to make sure its not storing any codes. The coolant thing was probably an air bubble somewhere, did you try bleeding it?
    The Nissan KING! R32Dragon's Avatar
    Sumter
    Have you checked to see if your plugs are fouled to hell?
    and x2 on checking the rad fan.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    Vinings, GA
    I guess its seems to be fine right now.
    Vinings, GA
    Quote Originally Posted by skillzilla
    We didn't bleed it but it seems fine now. I'm waiting on a new MAF now and we did reset the other one with the new MAF in.
    Vinings, GA
    Quote Originally Posted by RX8Dragon
    The plugs are good and I don't think the radiator fan will need some attention. Reps to all for the help, if I can.
