Thread: crower question
    Default crower question
    Would crower 404 cams go well with boost on a built ls? i need to know before i purchase. and if it could it be daily driven?
    thanks in advance
    -Cortland
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    NAwasBEST NAG2I's Avatar
    metro
    i don't know for sure but they make turbo cams and then the 404s
    i almost bought 404s for my all motor build but went another direction
    i'm thinking the turbo cams crower makes would fit it better but might want another answer from a smarter person
    ATL_DA_Squad #3
    STREET<3LOVE
    Total Insanity helcat17's Avatar
    macon
    i would say that they will work with a good tune and i mean with a REAL good tune if your going boost i would definitely go with the 440 turbo cams you might try and find a crower
    distributer they would be able to give you a lot more info
    Flowery Branch
    i have something similar in mine from crower but a little more extreme and i drive mine daily on the break in tune.
    your moms house
    Quote Originally Posted by jadakid88
    thanks in advance
    -Cortland
    yes they work great you won't pick up much power but you should gain quite a bit of torque well worth the time and money if you ask me.
    just ask yourself this most b series vtec guys run type r cams for turbo builds right? ok well the specs on the crower 404's are very close to what a factory type r cams vtec lobe is.
    if you don't belive me dyno stock cams then change to these
    thanks man i should have deleted this i already got mny answer the forst day i posted this by mr. kidd. but appreciate the info anyway.
    Quote Originally Posted by all-mota
