Thread: ~~~~~~~MODDED GATEWAY LAPTOP~~~~~CHEAP~~~
    Default ~~~~~~~MODDED GATEWAY LAPTOP~~~~~CHEAP~~~
    CONTACT ME VIA PM, PHONE, EMAIL
    [email protected]
    404 729 4728
    My girlfriend got herself a new laptop, and so her old one is up for grabs...
    The stuff I did to the lappy was,
    40GB HDD to a 80GB HDD
    512MB DDR266 to a 1,024MB DDR400
    Add a internal Wireless Card w/Ant.
    CD-ROM to a DVD Burner w/Double Layer
    Clean Install with XP Pro Sp2
    I also install Microsoft Office Pro. 2007 and other useful software like Nero 8
    Also installed Vista Inspirat 2 v.1.0, Looks like the new Vista but on the favorite stability Windows XP Pro.
    The laptop will have a fresh install of XP Pro. with all above and a Brand New Battery which is in the mail. I'm including a DVD with the drivers, programs you might need and games and a copy of Office 2007 incase of a reinstall needed. Also a copy of Windows XP Pro. Sp2... And a 60 day warranty...
    GATEWAY 600YGR Specifications: (BOLD IS WHAT I CHANGED)
    Intel Pentium 4 1.6Ghz
    Processor packaging Intel® socketable micro-FCPGA2
    L2 cache 512 K
    Core logic Intel® 845MP chipset
    PCI Bus
    Processor side bus 400 MHz front side bus
    BIOS Phoenix BIOS
    512 KB Flash ROM
    SMBIOS 2.3 support
    ACPI 1.0b support
    APM 1.2
    Wired for Management 2.0 (WfM 2.0)
    System Memory
    Memory type 400-MHz DDRAM system memory
    Memory expansion options Two 200-pin industrial standard DDR-SODIMM sockets
    Accepts two DDRAM memory modules
    DDR-400 support
    1,024 MB maximum system memory
    Video
    Graphics controller ATI Mobility Radeon 7500
    256-bit 3-D and 2-D graphics accelerator
    Video memory 64-MB DDRAM
    LCD display panel 15.0-inch active matrix (TFT) LCD color display
    Maximum panel resolution:
    1,024 × 768 (XGA, 15.0-inch display)
    Maximum color depth: 32-bit (16.7 million colors)
    Supported video modes:
    XGA
    SXGA
    Maximum refresh rate 200 MHz
    External video Supports dual display and dual view
    Integrated TV encoder
    Maximum external CRT resolutions 1,920 × 1,200 × 21-bit colors
    TV out (composite video) jack Supports NTSC connection to standard TV monitors with RCA jack
    IEEE 1394 PCI interface link + PHY signal controller
    100/200/400 mps
    Supports video and audio capture
    Audio
    Audio chipset ESS ES 1988
    Sound support PCI interface audio
    Multi-stream Direct Sound and Direct Sound 3-D acceleration
    APM1.2, ACPI1.0, and PPMI1.1 compliant
    S/PDIF output for PCM or AC-3 content
    Digital DVD audio Provides full 5.1-channel Dolby Digital output (AC-3) from DVD decoder through Toslink optical S/PDIF jack on computer and port replicator
    Volume control buttons on front of system
    Software control provided through Windows
    Internal microphone Omni-directional, low impedance
    Internal speakers Stereo speakers built into palm rest
    1.0 W maximum output
    Audio jacks S/PDIF digital audio output
    Stereo headphone output
    Stereo line input
    Monophonic microphone input
    Supports AC97 V.2
    Supports playback function buttons (Play/Pause, Forward/Scan Forward, Rewind/Scan Rewind, Stop)
    Independent power button
    Communications
    Modem features Integrated V.92/56K data/fax modem
    Uses the RJ-11 jack on the back of the computer
    Supports Wake on Ring
    10/100 Mbps Ethernet interface Integrated IEEE 802.3 (10/100 BASE-TX) Ethernet interface
    Uses the RJ-45 jack on the back of the computer
    Supports Wake on LAN
    Wireless
    Broadcom 802.11n network card installed in Mini PCI expansion slot
    Wireless Ethernet features Uses factory-installed internal antenna assembly
    11 selectable channels
    2,412 to 2,462 MHz Direct Sequence Spread Spectrum
    Approximate open environment range:
    525 feet (160 m) at 54 Mbps
    855 feet (270 m) at 11 Mbps
    1,300 feet (400 m) at 5.5 Mbps
    40-bit (minimum) WEP and 128-bit RC4 security
    Programmable keys Four programmable "hot keys" (default functions: launch e-mail, launch Web browser, launch help application, user definable)
    Status indicators Caps lock
    PAD lock
    Scroll lock
    Hard Drive access
    Right bay access
    Left bay access
    Bay swap
    Audio DJ power
    Power/Suspend
    Battery status
    Input/Output (I/O) ports Two USB (4-pin)
    High-speed serial
    Parallel (bi-directional, EPP, ECP)
    IEEE 1394 (4-pin)
    V.90, 56K Modem (RJ-11)
    10/100 Ethernet (RJ-45)
    External monitor (VGA)
    TV out (NTSC/PAL composite video)
    Stereo line input
    PS/2 keyboard or mouse
    PC Card sockets (two Type II or one Type III)
    Docking port
    DC input
    PCMCIA Accepts two Type II or one Type III device
    TI PCI1520 controller
    Supports D3 cold wakeup
    Note: This computer does not support Zoom Video.
    Docking Solution
    Type Port replicator
    Docking supported Hot dock
    Warm dock
    Cold dock
    Input/Output (I/O ports) Two USB (4-pin)
    High-speed serial
    Parallel
    Modem (RJ-11)
    Ethernet (RJ-45)
    S-video TV out
    Analog audio line input (stereo)
    Two PS/2
    Docking port
    DC input
    AC adapter 19 VDC, 4.2 A, 80 W output
    Automatically adjusts for 100 to 240 VAC, 50 to 60 Hz power source
    3-wire design
    Includes power LED
    Battery type Main
    12-cell Lithium Ion battery pack Brand New
    Embedded controller inside to support smart battery
    Secondary
    Removable 9-cell prismatic Lithium Ion battery pack (Not Included but can add one)
    Power switch Power on/off or Suspend/Resume (selectable in setup)
    Reset button Resets whole system if computer cannot recover by power switch
    Lid switch LCD on/off or Suspend/Resume
    Security
    Passwords Power-on password (2-level password support)
    Hard drive password
    Kensington® security slot in notebook back
    Kensington® security ring on port replicator
    System Software
    Microsoft® Windows® XP Professional w/COA Sticker underneat
    Dimensions:
    15.0-inch display
    13.86 × 11.44 × 1.69 inches (W × D × H)
    System weight:
    7.55 lbs. (includes CD, disk drives, and battery)
    Bought this Power Supply b/c you can use it in the car and the house and charge USB items...
    The small cracks, does not bother with opening of the lid...
    --------------------------ASKING... $375obo------------------------------
    [email protected]
    404 729 4728
    01civic
    Henry County
    nice. gl with sale
    southside ATL
    bump for a nice laptop
    BABIES "R" US crew
    [Productions Team] flatop09's Avatar
    in a big place
    damn, thats a good price for a nice laptop. wish i wasn't broke rite now. .
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    Great deal. I wish I had the cash.
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    Laptop sale pending at 9 o' clock...
    Certified Gearhead njjfudge's Avatar
    Forest Park, GA
    Sold.....................
