Results 1 to 13 of 13
Thread: FMIC LEAKS?
    Lawrenceville, Ga
    Default FMIC Kit LEAK check?
    WHat is the best way to check for leaks on my newly install FMIC kit?
    2006 CBR F4i - (Sold)
    2007 Lexus IS - (Sold)
    2006 MazdaSpeed 6 - (Sold)
    IAs Most Hated OG!! BLK JDM's Avatar
    You'd have to pressurize the system just as a radiator. I've seen a pressure testing tool that AAP made. Basically block off 1 end of the intercooler completely and then pressurize the other end while making sure air is not leaking out that same end and listen for the leak. If it holds pressure than it's probably not leaking. Why do you think your intercooler is leaking?
    Quality Perfomance and Fabrication!!
    Lawrenceville, Ga
    Quote Originally Posted by BLK JDM
    I don't know if it is. I just converted my Mazdaspeed 6 from a Top Mount Intercooler to a Front Mount and I want to check and make sure that all the piping and everything had no leaks.
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    gwinnett
    Quote Originally Posted by KPowerEP3
    Good sh*t.
    The beach.
    Use that, or something similar, but don't listen for loud hissing, cause you could have a smaller leak. Use low pressure, and put the intercooler in a tub of water, if you see bubbles, you got a leak.
    Ellenwood
    Quote Originally Posted by Justin.
    Small leak or larger you can hear air escaping if you listen.
    The beach.
    But for a sure fire way to find a leak....water is your best bet.
    JDM TYTE AnthonyF's Avatar
    easiet way to see if it has any leaks...drive the car. Check your boost gauge, get on it hard to see if the pipes blow off. If Not, your good.
    Rican-are you running worm clamps are T-bolts? Look into getting t-bolts. They look nicer, work better, and dont tear up anything. They are about 5 bucks a clamp but they apply equal pressure all the way around the pipe.
    The Carbon Fibered R6
    i'm a got dang wallaby!!
    T BOLTS FTW! soap and water in a little spray bottle helps me alot just soak'm down
    buford ga
    MAn i had boost leaks like hell with my car so i just got a boost leak tester and went to work.
    DA KOOLAID MAN MIKE.P's Avatar
    conyers
    thats what you need to do! boost leak test...we made a bad arse one with parts from home depot
    06 rr rs
    03 rr evo
    6xx hp @ 3x psi *sold*
    http://www.youtube.com/watch?v=99CakHqCUMA
    Quote Originally Posted by stay_up
    yea..but u have a dodge...
