Results 1 to 40 of 49
Thread: ****FORCED INDUCTION WHP REGISTRY****
    Default ****FORCED INDUCTION WHP REGISTRY****
    Post up your Turbo setups and numbers, make and model an ill get a list going so we know who is who in the A-Town!
    HONDA/ACURA
    Instunoodah- SC61 Integra 375 whp/259 tq
    -t3/t4 50 trim, 38mm wastegate, log manifold, pump gas, gsr block 10.1 84mm je pistons, eagle rods, ferrea valves std valves, rocket springs & retainers, victor x
    01CDMLUDER 2000 Prelude 234Whp 203tq
    -Jackson Racing SUpercharger
    Honngodda411- Honda Accord F22 263whp/291TQ
    -t03/04 63 stage 3,450 injectors,AFC,OBD 1 conversion,Stage 4 6 puck clutch,8lb aluminum flywheel,OBX helical LSD,Ported and polished Head
    FMIC
    CHEVROLET
    FORD
    DODGE
    TOYOTA
    GGPIS3- Lexus IS300 452whp/447 rwtq
    -NA 2jzgte, 62-1 , 550cc, Greddy Emanage, XS Power Turbo manifold, Tial 44mm WG
    MAZDA
    NISSAN
    Mr. Kidd- Nissan 240sx 705whp/560TQ
    -2JZGTE, GT45, 850ccinj , XS Turbo Manifold, Crower 280 cams, TDF Intake Manifold
    BigJ- Nissan Sentra Spec V 304whp/289tq
    -Treadstone Performance Turbo Kit, T3/T4 .63 stg 3 turbine 50 trim .50 compressor, 500cc inj, FMIC, 3in exhaust
    AllTheDude -Sentra 241 whp 261 wtq
    Mr. Kidd- Nissan Silvia 227whp/211TQ
    -FMIC, DP, Boost controller
    Senior Member 95alty's Avatar
    WELL... KA-T 95 nissan altima with an S-15 t28 true garret turbo, eagle rods, arias pistons, turbo back exhaust, bored block with low compression, aeromotive fpr, walbro 255 fuel pump, and I guess that's it... I believe the power is between 220-270 hp depending on the boost set...
    PIC TOO BIG
    2004 Nissan Sentra SE-R Spec V aka "1.8s"
    stock block
    SRT-4 stage 1 499cc injectors stock fuel pump
    Treadstone Performance Spec V kit
    3" catback
    torque FTW
    5psi 271whp 257wtq
    8psi 304whp 289wtq
    Future plans: 8 counter wieght crankshaft from '07 Spec V motor, 9:1 CR pistons, Scat rods (being made), 350z springs, regroud cams (2 sets waiting to send out), sc61, 7200-7600 redline, 255 walbro fuel pump, clutch and flywheel, p&p head w/ thermal coating (2 heads in the garage), custom intake manifold (working out specs now), 60# motron injectors, no2 intercooler sprayer, ECU reflash (JWT is working on this for Nitto time attack car), suspension, larger MAF housing, and w/ the power it'll make a roll cage might be in order, hopefully that'll get me in the 13's....................lol
    DA KOOLAID MAN MIKE.P's Avatar
    conyers
    were is mitsubishi on the list????
    good numbers J...i saw were you called hit me up tomorrow!!!
    06 rr rs
    03 rr evo
    6xx hp @ 3x psi *sold*
    http://www.youtube.com/watch?v=99CakHqCUMA
    Flowery Branch
    95 accord, h22a swap, fully built and sleeved, still on break in and 550cc inj, greddy 18g turbo making 236whp on 7lbs, coming to see you soon with sc61 and 800cc's, gonna need a tune as well
    Carless Ericp's Avatar
    McDonough
    Old Car.......2004 SRT-4
    Stock Turbo spiking 22psi falling to 15psi by redline
    Aaronneon Fuel Return Line Kit
    AGP Wastegate Actuator
    AGP Hard Hot Side Intercooler Pipe
    AGP RACE Front Mount Intercooler
    Boomba Fuel Rail
    Coolingmist Trunk Mount Water/Methanol Injection Kit
    DCR Top End Modifier
    K&N Cold Air Intake
    NGK 4306 Spark Plugs
    Needswings Manual Boost Controller
    Needswings Down Pipe
    Custom Side Exit Exhaust
    Walboro 255lph Fuel Pump
    Apexi S-AFC II
    Tuned at Mainstream Performance
    287whp 334wtq with a boost leak I'm sure
    -zen motors-
    at the shop
    i know my car is slow but no category for Lexus? booohooo
    452 rwhp and 447 rwtq was my last setup on pump gas no nitrous. i'll let you know how the new setup goes..
    superduper LLLLLLLLL
    250whp
    150wtq
    gt4088 h22 civic!
    -zen motors-
    at the shop
    Quote Originally Posted by AnclyT
    250whp
    150wtq
    gt4088 h22 civic!
    cough bs cough... maybe at 1psi
    BK ALL DAY
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    >100K AllTheDude's Avatar
    Duluth, GA
    241 whp 261 wtq with <50 miles on the rebuild with Halfbaked's old SR20DET SE-R
    2003 Saturn Ion QC 3, 5 Speed, N2O (DD)
    1992 Nissan Sentra SE-R, SR20DET,
    241 whp/261 wtq (Sold)
    I foresee thread failure.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    Ill clean it up an add everyone sometime this weekkend
    KEEP POSTING
    Is Force-Fed Honngodda411's Avatar
    Hogansville
    97 Honda Accord
    F-22 B2 stock block
    t03/04 63 stage 3
    450 injectors
    AFC
    OBD 1 conversion
    OBX helical LSD
    FMIC
    263 Wheel Horse power & 291 Wheel Torque @ 11.5 psi 93 octane (Amoco ultimate)
    Duluth, G-nett
    SC'd Titan with 100 shot nitrous. 650hp and 620 torque
    Total Insanity helcat17's Avatar
    macon
    i know its slow but heres mine just for a good laugh
    94 integra ls
    t3/t4 63 stg 3
    walbro 255
    450 dsm
    stock bottom end
    3" turbo back with cat delete
    200 whp @165 tq on 5.5 psi
    in the process of building the motor now
    Cambodia
    t3/t4 50 trim, 38mm wastegate, log manifold, pump gas, gsr block 10.1 84mm je pistons, eagle rods, ferrea valves std valves, rocket springs & retainers, victor x... 375 whp/259 tq @ 18 psi
    At Home
    00 Accord
    I/H
    NX Wet 50 Shot
    174.92 WHP / 171.45 WTQ
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    voung, that trucks a ****ing sleeper!
    Certified Gearhead 01CDMLUDER's Avatar
    00 prelude
    s/c'd
    234Whp 203tq
    up
    UPDATED KEEP THEM COMING
    All bark, no bite.
    630whp/411ft lbs @ 28psi.
    GT35R, 2.0L GE block, DFE LS head, TurboDave top mount, MSPi tuned.
    '00 Acura Integra LS
    For old time's sake...
    JDM TYTE AnthonyF's Avatar
    Mike, sticky this, I'll get my numbers up in a few months.
    The Carbon Fibered R6
    I'll post this for a friend
    2003 Nissan Sentra SE-R Spec V (Mike Kojima's Nitto Time Attack car)
    Stock motor w/ JWT balance shaft removal kit and JWT cams (built race motor being prepped)
    Custom JWT turbo setup
    GT3071, 56 trim 71 mm compressor, .50 a/r TO4S compressor housing, 76 trim 60mm turbine with a .82 a/r turbine housing
    ON RACE GAS:
    "418 whp @ 12 psi of boost and 5500 rpm. 380 lb/ft of torque. Stock motor with JWT cams and BSR.
    Lots more tuning to be done. Maybe I don't hate the QR quite so much.
    Built motor being retrofitted with bigger JWT cams, epoxy filled block, studs, 07 head gasket, Cryo and WPC treated 07 crank, swain coatings and WPC treatment of all frictional surfaces."
    **** your SR's and KA's
    One day people will figure out the 2004+ Nissan Frontier pick ups run a QR and 5 speed tranny. It's probably the only motor that hasn't been swapped into a 240sx.
    I am thankful for my Son
    Tyndall
    Post
    Here we go
    1995 bb1 Jdm h22a
    rc 310's
    smsp knock off header
    test pipe
    Type s pistons
    Crower 2's
    block decked 10k's
    head milled 5k
    bull**** cam gears
    Hondata s100
    2.75 inch exhaust with apex N1
    204 whp 168 lbs.tq.
    Tuned by Ed @balanced
    1997 Type R
    Jackson racing blower
    rc310's
    jdm type r header
    225 whp 18x lbs.tq.
    1999 Civic Si stock sleeves
    HKS HUGE FRONT MOUNT
    je. 9.5:1
    eagle rods
    jg edlebrock intake mani (the first one, with the huge runners)
    Fully ported head and Type R cams
    Rc 440's
    Greddy 18g kit, cutsom 3inch down pipe 315 whp 15-17lbs. with creep (modified wastegate flapper etc.) Fast ass street car!
    Tuned by Ed @ balanced
    1999 civic si same car as above except turbo kit and bottom end.
    Benson sleeved 83.5 mm Gsr block
    same allaniz ported head with type r cams
    hondata s200b
    nuekin a/c ramhorn
    t3/t67 base model non h.o.
    3inch dp
    rc 750cc injectors @ 110 percent duty cycle, then changed to precision 880's on the dyno, thanks Ed.
    482whp on pump with 327lbs.tq.
    Trying to find my list on my race gas tune for the si and my dyno' for my 95 4dr gsr with the vortec blower.
    1997 GSR b-20 bottom end block guard
    je. 10.8;1 pistons
    eagle rods
    Toda B's
    Hytech slip fit ino collector header <sp
    9lbs flywheel
    portflow head 3 angle valve grind polished bowls etc. (sweetest head)
    rc 310's
    211whp. 167lbs.tq. Plus a 100 wet shot.
    2004 Subaru Sti
    Perrin 35r kit built heads 1k cc injectors
    solid sleeved fill job Scott's machine shop did it lol, awesome job too.
    601 awd hp. 487lbs.
    This car had all of Japan's bolt on's ever made. lol
    I have to find my dyno sheets, but Mr. Kidd can vouch for just about all of these, as well as many others
    Trying to find my Evo dyno as well.
    66 Chevy ii 502 crate motor ross 11.1 pistons
    manly rods
    Roller cam
    Brodix aluminum heads
    twin demon 750's
    1o4 fatty long tubes
    nx 250 shot 2 stages 2300 stall with a muscle shoals 2sp glide.
    Never dyno'd
    Stupid fast 5.90' on motor all day long in the 1/8 Never sprayed, need a taller rear end and a biger tub job. 4 link with 10.5's Need to have the cage ripped out and get Turbo Dave to build a 7 cert. setup
    Quote Originally Posted by 2.0 under pressure
    Here we go
    1995 bb1 Jdm h22a
    rc 310's
    test pipe
    Type s pistons
    Crower 2's
    block decked 10k's
    head milled 5k
    bull**** cam gears
    Hondata s100
    204 whp 168 lbs.tq.
    je. 9.5:1
    eagle rods
    Rc 440's
    I remember both those cars from the Street Races back in the day, the prelude was mean for what it was.
    Remember your SI blowing the clutch up when we went to commerce and it smoked and stunk like hell all the way home LOL
    good time
    Tyndall
    good time
    Twin plate FTL, that junk ass clutch was in the car two whole hours after break in before it **** out, Jackie was so mad she bought that **** for me, lol.
    Oh yeah the my dd beast. Bone stock 01 Type R. Slow!
    02 WRX patrick4588's Avatar
    warner robins
    one day... one day...
    GCO Member
    NRA Member
    BOOST Gets U LAID
    Cedartown
    520whp/384tq
    93 EG GSR
    sc61 Turbo
    Peakboost FTW Manifold
    Greddy FMIC
    Type R Crank
    Crower I beam Rods
    Arias 9:1 Pistons
    Block Gaurd
    P&P head 3 angle Valve job
    1mm oversized Ferrera Valves
    Toda Cams
    Titanium Retainers
    Crower Dual Valave springs
    BBK SSI Intake Mani
    BDL 70mm Throttle Body
    436hp/396tq
    gt35r- hks,272 cams, walbro fuep pump, 880 injectors,hks bov.buschur upper and lower intercooler piping.3" hks exhaust.stock block,stock tranny running off a flash. at 24 psi. hoping to get my utec installed and run ras gas and up the boost a little. should be well over 500hp.
    abcdefghijklmnopqrst afwfjustin's Avatar
    Too many mods to list. 400/285 @ 11psi and 9:1 compression. Should be at 500rwhp @ 16psi the next time I tune.
    New car:
    95 S14 with RB25DET (stock boost)
    Old car:
    Turbo S2000 400hp/285tq on 9:1 comp & 11psi
    Senior Member onebadgt's Avatar
    2006 mustang baby turbo 4xx/4xx hptq @ 8psi
    2006 mustang gt
    gears
    bolt-ons
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    199 rwhp / 237tq
    fuel injectors topping out duty cycles at 5kish
    t3t4 turbo, stock injectors, stock fuel pump, 11.5psi
    i'm not sure if this is the 199 pull, but here's one of them
    at mainstream performance, Scotty.
    new numbers 9psi pump gas:
    316.48 whp and 296.84 wtq
    05 f150 whipple supercharged @ 9lbs 398.02 hp 416.97 tq
    Certified Gearhead miro_gt's Avatar
    my stock D made 232whp/206wtq at 14psi on a modded GReddy 15G kit
    but I drive it at 15 pounds daily, for the past 15K miles
    on stock fuel pump, lol
    Shouldn't people post up what kind of car they are describing?
    s13 240sx w/ s13 blacktop sr20. big intercooler and 3" exhaust. stock turbo running safc at 12psi. tuned at mainstream.
    ATL, GA
    S14
    S13 SR20DET
    FMIC
    Megan elbow
    Project Nissan Test pipe and Down pipe
    AFC NEO
    Stock boost, stock exhaust...
    178hp
    178tq
    with wrong spark plugs and no o2 sensor.
