Results 1 to 13 of 13
Thread: Fog light wiring question....Caused battery drain
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Exclamation Fog light wiring question....Caused battery drain
    I wired up some fog lights to my car earlier today, and i drove it somewhere...parked it for a while, and then when i came back, the battery was DEAD. I had my hot wire essentially attatched to my battery. OBVIOUSLY this wasnt the place to put it. Where can i splice my hot wire into so that it wont drain my battery??
    \\\ATLANTA~ATNALTA///
    Norcross
    bump need help!
    hook it to ur light switch
    KEITH atlvi3tb0i's Avatar
    Clayton County
    or hook it to a hot wire that cuts off when you trun off your car
    Norcross
    I hooked it into my cig lighter...is that okay?
    decatur
    Quote Originally Posted by madking411
    no, you need to tap into a power source that has a switch, otherwise your lights will be on the whole time the cig lighter has power. if you dont mind the fogs being on whenever your lights are on i would just tap into your headlights.
    Norcross
    I forgot to mention....i do have a switch involved....
    decatur
    that changes things but i would still tap into the headlights unless you plan on running the fogs without your headlights off
    This sounds like an electrical fire waiting to happen. Make sure you have some in line fuses and such because this sounds ghetto. And near your fuse box you should have some 12v power sources that only work when the car is on, so you can probably tap into one of those.
    ***Lotus Elise***
    BlackWatchRacing
    decatur
    ^^^aka headlights.
    Norcross
    there is also a fuse involved...its in the hot wire.
    lol u need a fog light button.
    Norcross
    Nah i got it all set up right now.....
    THanks for yalls responses though
