Results 1 to 16 of 16
Thread: B Series Clutches
    FUK IT! bowdown201's Avatar
    Next Door
    Default B Series Clutches
    Are they all the same? Just wonderin cause im about to put an LS in my hatch w/ a B16 Tranny. Which clutch do i use the LS or B16 or are they just the same?
    the only differance in any B series clutchs are the cable/hydro tranny through out bearing. so if the clutch is for a cable tranny and u are putting it in a cable tranny ur ok...same thing if its a hyrdo clutch and its going in a hydro tranny.
    Next Door
    Quote Originally Posted by CH@Dbee
    Thanks Chad...If you come to the southside this weekend ill shake your hand lol
    San Diego, CA
    LIES!
    GSR/LS trannies (even if both cable...) some years have different discs...
    Get yourself the clutch that matches YOUR TRANNY. NOT your motor...
    JDMadness ==> EvasiveEF9
    Quote Originally Posted by EvasiveEF9
    LIES!
    i work for competition clutch. all B series clutchs use 8026/8027 through out bearings depending on cable or hydro tranny, 3-694 pressure plates and 99785 discs
    his clutch will match his tranny and motor cause what else are u gonna use with a b series motor than a b series tranny?
    Former Neon boy knows his Hondas!
    HONDA 4 LYFE!!
    San Diego, CA
    Then wtf clutch did I get?
    I bought a clutch for a cable LS tranny. The disc would NOT fit on the shaft. Hole was too small.
    Any guesses?
    MEGATRON 112480's Avatar
    Mobile,AL
    Good question
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    Quote Originally Posted by KevinT707
    HONDA 4 LYFE!!
    before the neon i drove hondas for 6 years
    Any guesses?
    it could have been a b series with a small spline but his being an EK it has a hydro tranny they all big spline discs. i was mistaken when i said ALL b sesiers discs are the same...ALL b series HYDRO tranny discs are the same.
    yeah i suck
    Next Door
    Its actually going in an EG but its still gonna be a hydro tranny so that doesnt make any differance tho right?
    Quote Originally Posted by bowdown201
    if its a clutch for a hydro tranny and the clutch is going in a hydro tranny is doesnt matter if its a b18b, b18a, b18c1, b18c5 or b16
    as long as the clutch is from a hydro car and its going in another hydro tranny then u are good to go.
    Next Door
    yea thats what i figured...preciate it man
    SOUTHSIDE
    on cable tranny they all dont fit cuz i bought an ls clutch before but i was using a ys1 tranny and it didnt fit so i had to buy one for a 92-93 ls the ys1 is a tad bit bigger i'm talking about hole for the clutch disc.....
    San Diego, CA
    yeah i suck
    Quote Originally Posted by wrekonize
    Read prior posts...
    yeah i suck
    huh? there's only one Civic that even came with a b-series and that's the 99-00 SI so what would it matter what car or year it was going in?
    But you're right, all hydraulic B-series should have the same disc while there are at least two differant versions for the b-series cable transmission. Can't remember which one is which though? Maybe the [Y1] B16a is the small spline and the [YS1] B17a1 & B18a1 are larger spline cable transmissions?
    Augusta, GA
    the 88-91 B-Series Cable Transmissions (Usually have a gold sticker with black letters) have a different disc than a 92-93 cable transmissions ( white sticker with black letters )..
