Results 1 to 13 of 13
Thread: Oil leak question!
    Norcross
    Default Oil leak question!
    ok so i went to look at a car today, its a 94 gsr swap eg, and when i went there was an oil leak coming from the vtec solinoid area all the way down over the b18c1 code stamp, it also looked like it was coming from where the bottom block n head meet the owner said the vtec solenoid was leaking and it jus needed a new O-ring.well vtec kicks in but smoke comes out of the exaust when you first gas it. any idea if the smoke is because of the leak? and how could the leak be fixed. and where could i take it to get a proper inspection over everything, engine tranny, brakes etc. thanks for help in advance
    Senior Member BlkCD5's Avatar
    oil leaks are such a *****. Degrease the engine and put that oil dye in the motor. Then drive it for two weeks give or take. The dye has a chemical that will show the concentration of the oil leak under a black light. Good luck
    Norcross
    ^^thanks any othe suggestions?
    San Diego, CA
    Rebuild...
    ...no, but seriously...replace some of the gaskets, rings, and seals in the area the oil's coming from...
    JDMadness ==> EvasiveEF9
    LAWRENCEVILLE
    replace the o ring and teh the cam seals in these are prone to leaking!
    San Diego, CA
    Very true...
    ill check it out, but I would do , dizzy 0 ring, vtec sol gasket, vc gasket n cam seal to start
    Norcross
    ^^ i would take it to u, but it has no tag so i cant drive it too far, how much would u charge to look at it. the owner said he will fix the leak, i jus want to make sure its done properly and that everything else is in tip top shape. would hooking it up to a machine help find problems? im gona take another look at the car on friday
    San Diego, CA
    Jump in the game. Don't be afraid of that thing...
    Order a HONDA gasket (GO OEM! HEED A TRUE BUILDER'S ADVICE!) and replace it yourself. It's not hard, man, I promise. Don't be afraid to get dirty...
    oem gasket fttw ...agreed
    San Diego, CA
    I mean you can refer to Napa for some OEM or ALMOST OEM parts...but when it comes to quality, nothing tops OEM with Autozone shortly behind. But when it comes to something cheap like gaskets and seals and stuff...go OEM. Every time.
    Norcross
    Quote Originally Posted by EvasiveEF9
    not afraid of getting dirty.. jus afraid of ****in up the engine kuz i dont kno what im doing lol
    San Diego, CA
    You probably know more than you give yourself credit for...
