View Poll Results: which are better!?
Voters
29. You may not vote on this poll
  • B18c1 cams
    14 48.28%
  • B16A cams
    6 20.69%
  • other??
    9 31.03%
Results 1 to 26 of 26
Thread: GSR cams VS. B16 cams
    Around metro-ATLANTA & IA!!
    Default GSR cams VS. B16 cams
    delete, this thread makes no more use
    Flooding IA with JDM dc2teg2006's Avatar
    here is a website that tells you about the different cams and motor spec!! scroll to the middle it will tell you about the cams.
    http://www.nof3ar.cjb.net/
    Augusta, GA
    i've swapped out my b16 cams for gsr cams. I say it wasn't worth changing them, cause there wasn't a noticable difference to me in overall acceleration.. there was a little more midrange around 5k or so..
    YEAH! bRiAnMcIvIcS's Avatar
    Just go buy some ITR-CTR 00'-01' spec cams. Those are the best honda OEM cams. The gsr are slightly better than the b16, but not worth the swap.
    Class of 2010 Ch0psticks11's Avatar
    Queen City
    i hear that the gsr cams are supposed to be some of the best oem cams for boost
    Weekly Gwinnett/Junciton Meet
    b16 are more for top end compared to GSR, but for boost GSR FTW
    Titties!!!
    Quote Originally Posted by bRiAnMcIvIcS
    nope get a set of CTR cams, they open more on intake side, but if you combine the CTR intake cam with a ITR exhaust cam i think thats the best bet, i'll look it up. after looking it up the ctr cams have more duration and i do believe they are a little more aggressive. remember 185hp out of a 1.6= 115.6/liter. heres the link to compare. and remember, put the dual valve springs on the exhaust side if your gonna rev, or to do on the safe side.
    http://asian_e.tripod.com/Honda_Engine_Specs.htm
    Stan The Man TallGuy's Avatar
    Dacula Ga.
    on my old crx i replaced the b16 cams with the b18c cams and noticed a good bit of mid range power. but I had the a1 and a be leave it has the weakest cams for the b16 line.
    Titties!!!
    Quote Originally Posted by TallGuy
    you are right. on the 2nd gen b16 the intake cam is way better. look at the link above. i noticed a difference after putting the jdm b16 in my si vs the us spec b16a2. the intake cam loves my aebs manifold and intake. thats my opinion.
    TheMyth
    i would say the gsr cams are better for na(in a b16) and better for boost than the b16 cams.
    GSR cams are cheap $60ish and it made a difference on my OBD0 B16, 3-4 WHP/WTQ when I had it dynoed before and later. OBD0 B16 cams are the worst, OBD1 B16 cams aren't too bad but GSR is better than both.
    Hwy 315
    why waste the time in installing a cam that will only give (according to kevin's dyno) extremely minimal gains? (and i use the word "gains" very loosely there)
    If one is considering a cam upgrade, at the very least take PrefferedDuck's advice... that will be a nice turbo cam setup, or a relatively low level NA setup.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Titties!!!
    Quote Originally Posted by se7en
    -jonathan
    i have wanted type r cams in my car ever since the motor swap. on the first drive you heard a lot more from the front of the car than before and i know a type r intake cam is aggressive for an n/a build. gsr would be better for boost?? i've seen more turboed b18's than b16's.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    ITR cams ftw!!!!
    98 Acura Integra LS-DD
    ??????????????????-project
    Certified Gearhead EK Hotch's Avatar
    Canton
    ^^^Yeah!! Why is everybody turboing b18's and not too many b16's?!^^ My wife has a b16 in her del sol and I have a couple gsr heads lying around.....was thinking about throwing those b18 cams in her b16......does that sound like a good idea?
    Swamp
    it is not worth the time or the effort to change your stock cams to anything less than type r cams. plain and simple
    Hwy 315
    Quote Originally Posted by 95egex
    ITR cams ftw!!!!
    RM M24x > ITR/CTR cams
    -jonathan
    [/URL]
    !!!!!!!!!!!!! AGREE!!!!! Get you some damn type r cams an be done with it!!!!
    Quote Originally Posted by smote
    ek hatch
    Macon
    yea iv been thinkn bout what to do to my b16 to ad a lil extra pep, so i guess il hunt me down some itr cams. Whats this about one itr and one ctr?
    97ek hatch
    that will work too. there is no big difference in any of the type r cams. I believe CTR's are the biggest though. You wouldn't notice a difference from any one type R cam to another.
    Certified Gearhead Rsxguy's Avatar
    put some itr cams
    01 Model though!! change the valve springs on the exhaust side also !
    Quote Originally Posted by Rsxguy
    put some itr cams
    Proud Mr2 Turbo Owner
    Subherbs
    Skunk pro stage 1 thats all you need to know about cams
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    Paint Guy Ricer's Avatar
    Petoskey, MI
    from what i understand... if you have a B16A2... GSR cams will help... but the gains are very minimal.. but if you have any older version of the b16... they'll give you a few more hp... but like everyone said.. if you're gonna go through the work of changing cams... go for something better
    thanks for all the comments, i just purchased crower stage 2's for my setup so thanks for all the info and stuff thanks!!!!
    you should be happy with them. I have some stage 3's and I love them
