Results 1 to 24 of 24
Thread: HELP? Squeal coming from transmission...
    West Staines
    Question HELP? Squeal coming from transmission...
    Okay check it...
    I got this problem see... from time to time when i disengage my clutch i get this squeal. it happens when i'm like half way having the gas pedal down and half way from being totally off the clutch.
    yeah... so... however long i stay in that mid area of being on and off, thats how long the squeal lasts.
    What dat iz?
    I dont know if it matters but it started to happen after i installed my CC clutch and a CC 9lb FW.
    Any help is preciated
    ( CC= Competition Clutch )
    New throw-out bearing right? Did you do a proper break-in on the disc? How many miles on it so far?
    West Staines
    yup
    so far id have to say theres no more 2k . i dont drive much but to work and home and the occasional Varsity meet. and its probably been about 4 months since ive been making my usual commute.
    yup
    There should be a drain hole in the bottom of the bell housing, spray some WD-40 up in it...I guarantee the squeal will go away
    (hahahah, j/k don't do it!)
    West Staines
    didnt some noob do some mess like that before?
    nah i think it was some dude put water in the motor?
    what was it? shoot. oh wells....
    could it be a Transmission Fluid issue?
    Either way put GM Synchromesh in it, it's astroglide for your gearbox.
    ek hatch
    Macon
    Does it do it when your not pressing the gas,and just pressin the clutch
    97ek hatch
    West Staines
    aight. will do. i think thats what i used when i initially put in my GSR tranny. but do you think it will help stop the squeal as well? do you have any other suggestions?
    Quote Originally Posted by killerdx
    it happens when im pressing the gas and getting off the clutch. at the mid point.
    The clutch disc is chattering. You're hearing harmonics coming from it.
    West Staines
    Quote Originally Posted by Init2winit
    is this normal? or does it need to be tended to.
    Columbus, OH
    Mine does it. I like the sound. But... it hasnt caused a problem for me yet. My clutch isnt new though... so maybe I'm commenting bout the wrong thing here. But its been like that since I've had mine.
    CHASE ->>>
    WHAT MATTERS
    Has it always done it? Chatter is normal for some lightweight flywheel/clutch combos...it's a sprung disc right? normal disc or mult-puck?
    I have the 8.5lb Cusco single piece chromoly flywheel and HD Clutchmaster stage III pressure plate with an ACT street disc...by far the best combination i've ever driven on a sub 200hp b-series.
    JDM TYTE AnthonyF's Avatar
    maybe it is just your pedal squeaking. ive seen things like that before. turn ur car off, kneal down and push the clutch with ur hand. if ya hear something spray some wd40 on it and move the clutch. if thats not it, it's because it's a honda. lol. j/k
    The Carbon Fibered R6
    West Staines
    its always done it ever since it was installed. i'm starting to believe i have the Competition Ultra Lightweight Flywheel, that is recommened for stage 2 clutches and up, mated to a "stage 1" Gravity series clutch kit.
    i put up a WTB a while ago for a lightweigt flywheel but upon purchasing the FW i didnt do research. partially because i didnt know exactly what model it was to begin with.
    So this could be all my doing by not necessarily having mismated parts but parts that werent actually recommended to go together.
    here are the specs on my parts...
    Stage 1 - Gravity Series 2400 Clutch Kit
    The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel. DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
    The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool.
    Forged Ultra Lightweight Steel Flywheel
    The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies.
    Qualities of the CCI Ultra Lightweight Steel Flywheel:
    One piece ring gear for high durability
    Weight varies from 8 lbs. to 10 lbs. depending on application
    Well suited for Stage 3 and up clutch kit applications
    Recommended for forced induction and/or track and rally racing applications
    Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
    CNC machined and balanced to O.E. specifications Reduced Mass = Increased Accleration
    thats all i could read. stood out like a sore thumb. lol. sorry. it's funny
    West Staines
    ^^ did u see my other post? check the actual pedal
    West Staines
    yeah. but that aint it. cuz its clearly coming from the transmission
    o boo...urs is an external slave right? possibly that?
    West Staines
    yeah. but changed that too!!!
    i should take that shˇt back for sh.ts and giggles.
    have someone stick their head under the hood as you press and release the pedal...
    make sure they open the hood before they try to ram it in.
    West Staines
    to pin point where its coming from?
    I wouldn't say that its normal, but it will be fine as long as you can deal with the noise. Its kind of like brake pads squeeling.
