Results 1 to 3 of 3
Thread: DIY Ecu chipping (p28/p72)
    Default DIY Ecu chipping(p28/p72)
    This is a DIY Ecu chipping guide, if you have the skills,patients or just like doing things yourself like i do. this is a standard guide for the P28 ecu, other ECUs such as the P72 will not require the resistor included in the kit.
    Required tools:
    • Moates Honda ECU Chipping kit
    • Soldering iron(cheap radioshack iron will work)
    • De-soldering iron (radioshack model: 64-2060)
    • wire cutters
    • Thin Rosin core solder
    • philips screwdriver
    Optional tools:
    • cheap carborator cleaner**DO NOT USE B12-Chemtool**
    • electrical tape
    • old toothbrush
    lets get chipping
    1> Remove both top and bottom covers from the ECU.
    2> Remove all screws holding the circuit bored in place, and loosen the screws holding the main voltage regulator to the case.
    3> Remove the circuit bored, and use electrical tape to cover the small hole on the barometric pressure sensor.
    4>Spray the lower half of the ECU with the Carb Cleaner and use the toothbrush to scrub the plastic coating off. This usually takes about three iterations before it is clean. Clean both the front and the back. Also clean the area around J12.
    5>Once clean, Desolder the items outlined in this illustration:
    6>Remove J12 (or J4 for JDM ECUs)
    7>Solder the following components included in your kit to the indicated location in the ECU.
    ECU location:
    27256------------
    74HC373--------- (CMOS Latch)
    27256---------(28-pin DIP socket)
    CN2 (Pins 1 - 4)------(4-Pin Straight Header)
    R54----(1k Resistor)
    C51 & C52---(.1uF Capacitor)
    J1----(Red Jumper Header)
    27256----(28-pin ZIF socket)
    8> Insert the Blue ZIF Socket into the 28-Pin DIP Socket
    9>Reinstall Circuit Board into the case, remembering to tighten up the screw on the Voltage Regulator.
    Finished product
    sorry for posting in the wrong place!
    Props.
    +whatever.
