Results 1 to 15 of 15
Thread: Emission v. OBD1.
    Apr 2003
    Default Emission v. OBD1.
    My 94 LX Accord had an H22 Swap done (previous owner let Madahvi Motorsport did the swap). The thing is they didn't run the O2 sensor to the cat. Will that affect my emission somehow? I'm getting the car check next week, just want to make sure that everything's good and street legal before I bring it in
    I'm not too familiar with these, so I haven't a clue.
    Thanks
    Wanna-be-OG
    Newnan
    Quote Originally Posted by ATK_Designs
    My 94 LX Accord had an H22 Swap done (previous owner let Madahvi Motorsport did the swap). The thing is they didn't run the O2 sensor to the cat. Will that affect my emission some how? I'm getting the car check next week, just want to make sure that everything's good and street legal before I bring it in
    Thanks
    Yup!
    Apr 2003
    So I'd need to run that to my cat? If I remember correctly, it's Pre-cat for my Accord and not after cat.
    pre cat
    obd1 has primary o2 only before the cat.
    ek hatch
    Macon
    so u have no o2 sensor on tha car as of now,and if not arent u throwin an check engine light
    97ek hatch
    Apr 2003
    The car doesn't throw any CEL, but no O2 sensor
    The CEL light works, it's on when started the car, then goes off. I can smell that the car is running kinda rich, though it's only JDM swap with stock ECU, I/H/E mods only.
    are you sure the ecu isn't chipped and o2 disabled? if o2 is unplugged from the harness on a stock ecu you will throw a cel. now, if you have an o2 plugged in, but not plumbed into the exhuast on a stock ecu you won't throw cel and will run rich since the o2 tells the ecu that you are running lean since it's not in the exhaust flow.
    you might want to get underneath the car to see what is the case w/ the o2.
    Apr 2003
    Last I checked, there's no O2 sensor being pluged in anywhere.
    As far as the ECU goes, I was told that it was a stock P13. But I never really checked.
    Apr 2003
    Also, my other question is that if it's not there, where can I find the linkage for it? I have the O2 sensor, but not the linkage.
    i know all
    i think if there is no CEL it will pass emissions
    Wanna-be-OG
    Newnan
    Quote Originally Posted by tightflks
    Apr 2003
    naw, it won't. You can clearly smell that it's running rich.
    i know all
    what year is the car
    if its a year where they just plug it inthe machine itshould pass
    L'ville
    no CEL means you pass that inspection.... then, they take this tube..... and shove it up your *****
