Thread: Nippon Racing
    about this far.
    Default Nippon Racing
    i was looking for some cams for my dohc zc, and i came across some Nippon Racing stage two cams.. i have never heard of them before, and i wanted to know if any had heard of them and if i do buy the stage two cams what all would i have up grade in the motor..
    link http://cgi.ebay.com/ebaymotors/JDM-H...QQcmdZViewItem
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Henry Co.
    im thinking injectors and a good timing adjustment. say goodbye to your 500 miles per tank
    about this far.
    ok then i will get 450.. i'm still getting better then you!
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    about this far.
    no wait i wont have to touche my injectors they will be find.. i may have to advance my timing... and with cams your gas milage can be better....
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I got some type S pistons that I have not had any problem out of the were great quality I know it is not cams but I would not be scared of there other products
    Jonesboro/Stockbridge
    I believe in stage 2 you have to get upgraded valve springs and retainers. Retainers not so much but valve springs a must, unless you like coil-bind and valve floating.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by JDM onlyy
    agreed... and also, its not necessary but i would pop the head off, and order a custom MLS headgasket from Cometic and have the head milled or either the block decked so that the pistons actually come all the way up to the top of the deck to bump up the compression a little bit more...
