Results 1 to 21 of 21
Thread: ***The Big FAQ Thread- Honda/Acura, ECU codes, Swap Info, Wiring. READ FIRST***
    Default ***The Big FAQ Thread- Honda/Acura, ECU codes, Swap Info, Wiring. READ FIRST***
    WHAT SWAPS CAN I DO IN MY CIVIC/INTEGRA?
    B16 (1.6L DOHC VTEC)
    B18A/B18B (LS)
    B18C1/B18C (GSR)
    B18C5 (Integra Type R)
    K20A2 (Rsx Type-S)
    K20A (Rsx Type-R)
    Chassis vary on what is needed and how complicated it can be. My advice is to try an convert or stay OBD1 whenever possible. FOr OBD2 people, youll want to register in a non emissions county as its easiest to pass. But its still possible to pass if you perform all the wiring and conversions neccesary.
    All these engines require Mount kits, shift linkages, axles, Radiator Hoses, ECU to function properly or to even work at all.
    Where to Purchase Mount Kits/Shift Linkages:
    Hasport.com
    Innovativemounts.com
    Avidracing.com
    Where to Purchase Axles:
    Autozone
    Advance Auto Parts
    Hasport.com
    Where to Purchase JDM/USDM Engines:
    Ive only dealt with a few an ill list them as those are the only ones i can recommend. BUY AT YOUR OWN RISK, YOU GET WHAT YOU PAY FOR
    Hmotorsonline.com (ive bought over 50 swaps with NO problems and they are the only ones i reccomend)
    Jarcoinc.com (only place i will purchase Nissan motorsets from, EXCELLENT quality)
    Nadauto.com (bought 10 swaps from with no issues, talk to Bay)
    Jhotimports.com (bought a few 2JZs from them, decent price, decent quality)
    TOOLS NEEDED TO PULL AN ENGINE
    You need:
    SOCKETS:
    10mm-misc engine ,bracket bolts, radiator mounts
    12mm- misc engine ,bracket bolts
    14mm- misc engine ,bracket bolts
    17mm- motor mount bolts, Lower ball joint castle nut, lower strut bolt
    19mm- Rear bracket bolts, lug nuts
    32mm- axles
    WRENCHES:
    PLIERS:
    Angled nose PLiers (hose clamps)
    Straight nose pliers (hose clamps)
    Flat head Screwdriver
    Phillips Screwdriver
    8mm punch for ***** Pin if you have a shift linkage
    Hammer
    Breaker Bar
    2 Ton Jack
    Jackstands
    Engine Hoist ($100 at pepboys)
    those are pretty much the tolls you have to have to do an engine swap.
    Its pretty straight forward. Disconnect Battery. YOu want to start by draining all fluids from the motor, radiator, transmission. Then disconnect the wiring harness, im unsure on the preludes in that year, but there should be 2 main harness disconnects, one at each shocktower like on an EG.
    Youll want to leave the harness on the motor.
    After the wiring is disconnected, start unhooking all hoses that attatch from the motor to antyhing outside of the engine, like firewall heater hoses, radiator hoses(pull the radiator, gives yourself more room).
    Disconnect Power Steering and AC if applicable. Usually you can unbolt the compressor with the lines attatched , just undo the 4 14mm bolts from the compressor bracket. Same with the PS.
    After all thats done, disconnect the shifter cables or linkage. Remove axles, unbolt header from cat.
    Once all thats done, survey the engine, and make sure there is nothing that connects from the engine to the engine bay. Double check, remember your pulling the engine so any lines you missed the first time, double check now to make sure nothing else is in the way.
    Once all thats done, hook hoist up to the motor. I use the 14mm on the back of the head and the 17mm front TQ mount as places to put the chain.
    Jack the hoist up to put a SMALL amount of tension on the chain. Start undoing the engine mount bolts. Use your best judgement. I usually do the rear mount first, then the tranny mount from the trans, then the bolt to the tranny mount, then i undo the driver side mount.
    once thats done, have a friend help you angle the motor an pull it out , sometimes its best to remove the hood if its your first time to give yourself plenty of room.
    Once the motor is out, youll have to swap everything over to the new engine including trans, clutch, flywheel, wiring harness, starter, etc.
    HOW TO CHECK ECU CODES OBD1 and OBD2 Honda/Acura
    Do you have a CEL?
    Dont just reset the ecu by pulling the battery's neg. cable. Sure, that will reset the light, but youre not finding out whats wrong with your car! The light will always come back, until you fix it.
    This is how you check your own cel (Check Engine Light), at home, without driving to a mechanic, auto store, dealer. Numbers for the light are listed farther below.
    5 Easy to Follow Steps:
    1) Get a CEL
    2) On the passener side, remove the kick panel at the floor.
    Behind it, is your ecu and a jumper plug.
    3) Locate the jumper plug (Civic 92-95 is grey, 96-00 its blue). Its a 2 pin plug.
    For EK, there is 1 brown wire and 1 black wire
    For EG, there is 1 tan wire and 1 green
    4) WITH THE CAR OFF, insert either a 2pin connector clip, or loop a thin enough piece of wire into both holes on the connector.
    5) Back in the driver's seat, turn the key to the 'ON' position. The CEL light will come on at startup, like normal, but it will then begin to flash.
    **By counting the number of flashes, you can decipher the CEL #.
    SHORT flashes are single digits (1/2 second)
    LONG flashes are 10's (1 second)
    -----CEL # List-----
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor circuit
    65 Secondary oxygen sensor heater wire (black wires)
    67 Cat Converter
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 EGR Valve/Line
    86 ECT sensor - Cooling System
    91 Fuel Tank pressure sensor
    92 EVAP Solenoid/Valve/Vacuum Lines
    OBD1 Civic / Integra / Prelude ECU Pin Schematics
    OBD1 PLUG CONFIGURATION
    Below is an example that shows the common onboard male connectors for a Honda OBD1 ECU.
    OBD2a Civic & Integra ECU Pin Schematics
    OBD2A PLUG CONFIGURATION
    Below is an example that shows the onboard (female) connector configuration for an OBD2a ECU.
    Take note of plugs: A, C, and D.
    The blank connector (B) is only used with civic/integra vehicles equipped with A/T.
    HOW TO WIRE VTEC OBD1 CIVIC/INTEGRA
    HOW TO WIRE VTEC OBD2A CIVIC/INTEGRA
    For More Wiring Information, visit:
    http://technet.ff-squad.com/
    For Even more in Depth FAQ, Visit:
    http://honda-tech.com/zerothread/1998336
    directly from honda-tech . makes it easy for the lazy no searchers.... thats the best info you could ask for when doing a swap.
    Im just getting tired of people posting the same stuff over an over again.
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    FANTASTIC faq. we definatly needed it for the noobs.
    Who knows?
    Jonesboro/Stockbridge
    Good info! I know most of this but not everything and now it will be ready at a click when I need it. Thanks!
    LAWRENCEVILLE
    great thread this trick is ****ing great!!!!
    http://technet.ff-squad.com/ckftrick.htm
    yeah the CKF sensor trick is off da chain
    Trogdor!!! IOnlyLookStock's Avatar
    Awesome info man!
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    GoonSquadsNinja JDMjoe's Avatar
    i85north
    Excellent info!!!
    everywhere & nowhere
    Might want to add, that well-designed mounts is what is gonna increase the life of your axles. A lot of the earlier Avid (sorry Avid) and ebay mounts do not position the engine at the best angle for the axles - and the cv axles pay the price. GREAT POST.
    i85north
    Can you go wrong with used oem mounts???
    Columbus, OH
    Yea its a nice thread, but he still left out the 89-91 cars...
    CHASE ->>>
    WHAT MATTERS
    1badEg
    marietta
    Thumbs up Great info!
    Ive done a few swaps and have to say I wish I would have seen this before I did the first one. All this info is exact. anybody reading this to do a swap follow this to the T!
    aye bro .:Stirfry:.'s Avatar
    Quote Originally Posted by blaknoize
    x2 on that:.
    but awesome info
    ATL DAsquad Member #9
    Just a Dude
    Coch town
    excellent write up!
    Ill be needing this if i ever get a HB!
    no photo skills....
    Jul 2009
    senoia
    does anyone have a white up for the H22?
    Quote Originally Posted by 2jdm4drift
    what do you need to know?
    question, if im using a type r ecu, does it matter what cabin harness i use to connect it when im swapping out my ls head with a type r head and the motor with a b20b??
    Aug 2009
    Quote Originally Posted by MarkPeschlow View Post
    dude, you need to start your own thread.
    you will get more people result>
    you can swap motors all you want. The CABIN harness stays with the car with any EG civic or integra.
    The only car that you have to remove the ECU harness is an EK (the engine harness has the ECU harness built into it.)
    So if you have an EK, the head doesnt matter, you just keep your same wiring harness
    Champ
    Feb 2010
    Warner Robins GA
    whata champ
