Thread: FS: BUILT!!!!!!!!! 1995 Honda 300EX
    Where Am I
    Default FS: BUILT!!!!!!!!! 1995 Honda 300EX
    This is a friend of mine, if u have any questions about it you can PM EKHotch about it cause its his, all I know is this thing runs great and is pretty fast too, you will not be disappointed.......
    Up for sale is a 1995 Honda TRX300EX 4-wheeler. awesome running four wheeler. has scratches on the plastics but nothing serious. There is one rip in the plastic on the headlight cover. Every thing works fine, including the neutral and reverse lights.
    On to the good stuff
    He built the engine him self not too long ago, this is what he wrote to me so here's everything.......This engine is 340cc's. I had the old sleeve removed from the cylinder, the cylinder bored out, and a new thicker sleeve pressed in. I didnt just bore the old cylinder out. It has a "Powroll" High compression piston and Powroll Woods mid-range cam with titamium valve springs and caps and retainers. I lapped the valves, replaced the valve stem seals, as well as the cam bearings and the timing chain and upper cam sprocket. It has a Supertrapp exhaust, Uni Filter air filter and I completely jetted the carb. The engine in this quad only has about 40 hours running time since I rebuilt it, and it is very torquey. The bike also has titanium clutch springs and performance(I can't remember what brand...I think Hinson)clutch discs, and I went down one or two teeth on the drive sprocket to gear it down. It has new bearings all the way around. It also has DG Nerf bars, DG grab bar, Renthal handle bars and a twist throttle. The front tires have about 90-95% tread left...but the rear tires don't have much tread left. That's just about everything I can think of now. I can e mail more pics to serious buyers. I am asking $2000 OBO
    If you have any questions, you can PM me(EKHotch)or call me at 770-633-8923(Taylor)...please leave a message if he doesn't answer.
    Now for the pictures
    Certified Gearhead EK Hotch's Avatar
    Canton
    Yea this is mine if any one has any questions just let me know......
    If you look, please bump...I'll try to rep ya.
    Swamp
    B18c1
    woodstock
    bump yeah this is a bad a$$ 4-wheeler i have rode it and it is VERY NICE!!!
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    S**t is quick and built by the finest
    Where Am I
    Bump, come on people.........
    Canton
    Swamp
    Woodstock/Kennesaw
    bump for 35 lbs of boost
    Canton
    ttt
    Swamp
    ttt
    bump fora good deal, g/l
    Canton
    thanks
    Swamp
    Canton
    SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Swamp
