Results 1 to 39 of 39
Thread: Royal Purple=more HP?
    JDM TYTE AnthonyF's Avatar
    Default Royal Purple=more HP?
    I was watching some show. They had a brand new engine, looked like a small block v8 on an engine dyno. brand new regular oil and brand new oil filter. made xxx amount of hp and tq. Well, they changed the oil filter, and put in Royal Purple, ran the engine at the SAME temp and speeds and gained around 11ft lbs of tq and 8-9 hp. Can just oil do that? and how? is it that much thinner? If its too thin isn't it getting too hot inside? I havent really read up on R.P. but i dont feel like spending 10 bucks on a qt of oil.
    If my car ever becomes the garage queen then i'll think about it.
    The Carbon Fibered R6
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    rice boy..
    K-Town!
    Royal Purple = Rice
    ^^^ wow. 2 dumbass statements. honestly, why post?
    Canton, GA
    Royal Purple = waste of money
    that battle was full synthetic Vs. Non Synthetic/partial Synthetic im sure
    ^^ you are probably right. I wish i turned the channel on quicker to see what oil they were sticking in.
    Here and there Hulud's Avatar
    Omnipresent
    i use royal purple cause it quiets my lifters
    Val for President
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    thicker oil can do that to.
    I got dinner to goto.
    Omnipresent
    Quote Originally Posted by turbosx©
    i know some people have had good things with changing to 10w-40 and others, but ive also heard the same about royal purple, i might try 10-40 next time if i keep losing oil, cause i think it is seeping out through the seals
    but i cant see any evidence of drippage and im not burning oil either
    Val for President
    I put Royal Purple in my car and now I chirp 3rd
    Canton, GA
    There are plenty of variables that go into those studies that are "conveniently" left out. There was a show on Speed that was testing the new Corvette and different Fuel manufacturers/companies. they performed a baseline and test some 5-10 different brands. They found that in a week long study that certain brands of gas yielded higher performance gains. (ex. Shell/BP were as high as 9-12whp higher then Racetrac/QT/Exxon etc). all they stated in the test was that they filled up a certain amount, tested it, then filled with a different brands Gas. There is alot of information left out that could explain such a vast difference, when octane levels and fuel additives are set at standerdized levels across the board
    Its true some oil will def outperform another, but in the full synthetic market that difference is very narrow. IMO a Mobil 1 full synthetic used in a newer motor is your best bet. Its not expensive, its sold everywhere and performs just as well as any other oil on the market.
    Canton, GA
    DAAAAAAAAAAMN!!!
    K-Town!
    It was just a joke. I honestly didn't see his post before I posted. Relax man, live a little.
    Omnipresent
    did you have the lifter ticking goin on?
    Val for President
    so does adding in some ATF to your oil.
    lol. i am living. it was mainly to frog. 98% towards him 2% towards you. he likes to talk shìt.
    Omnipresent
    havent heard of that before
    Val for President
    Yep... IDCoconut's Avatar
    Atlanta/Kennesaw
    I use 15-50 in my car. High compression really runs hot and thins out the oil. I've tried royal purple on my car and really feel no difference compared to the usual mobil1 full synthetic.
    My father tried it also and really felt it was a waste of money for daily driving.
    I did but didnt use Royal Purple but hear good things about it, I used a heavier weight and the lifter tick stopped. It just does it for a second right when it starts sometimes. I might try Royal Purple next oil change.
    Quote Originally Posted by Sport20
    There is no such thing as Mobil 1 full synthetic After they lost the lawsuit to Castrol over the use of the phrase "full synthetic" they too quit producing a true full synthetic...yet they didn't tell the public and they still sell it at the same price as before.
    Canton, GA
    lol i forgot about that. Sorry, Semi-Synthetic then
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    Royal purple is pretty thick synthetic. There is no rating, its just royal purple synthetic. Its around a 20-50 though. It's not certified by ANSI standards because its not rated, and because of its viscosity. I've heard a lot of good things, and I've heard some not so good things. Consider if you have warranty, that the dealership can void that warranty because your not using a certified oil (which honestly, is the reason I refuse to use the stuff). A lot of people like it. Kinda expensive, I'll stick to me $23.38 5 quart jugs of Mobil 1 5-30 in the sky turbo
    2011 Camero - Fast
    1998 T/A - Slow
    IA Member jbhondatech's Avatar
    A Royal Purple rep would never tell you that this oil will give you more power. The oil does have a high tollerence to sheering forces and a long drain life. It is not the oil that gives these properties but the addative package they put into the oil. There normal oil is availible in standard weights and they also have a compatition grade oil that has a higher consentration of the addative. I have personaly seen this oil out perform mobil 1 and castrol the only thing that came close was redline. I have seen RP gain 3whp on a dynopac at Knowledge Performance. If you don't want to switch to synthetic then I suggest the BG product MOA this is the oil addative package by itself and can be added to any oil.
    Dyno means nothing when it comes to oil...
    with that said check out the dyno of RP, redline, amoils, greddy, mobil 1, and more here!
    http://my.prostreetonline.com/t2540.htm
    *cliff notes so far in order of dyno*
    350z is on the dyno
    -Pennzoil (reported what he already had in the car) - 224.59 hp and 220.46 ft/lbs
    -Greddy - 231.52 hp and 224.35 ft/lbs
    -Amsoil - 237.49 hp and 223.81 ft/lbs
    -Royal Purple - 242 hp and 226.53 ft/lbs (so far...read the link for more info.)
    -Mobil 1 - 232.78 hp and 217.43 ft/lbs
    You should be more worried about how well the oil will be in your car after a couple thousand miles rather than a dyno....
    i use RP by the way...lol
    very true
    \m/>_<\m/ dorin48's Avatar
    Canton
    Quote Originally Posted by Spinner
    = wrong
    Quote Originally Posted by jbhondatech
    = right!
    ita actually the same price as mobil 1 at Oriley's. For $7 a quart i would pic r/p.
    AMERICA FUCK YEAH
    cuz i feel like it b!tch!
    ATL, GA
    Quote Originally Posted by DarkMystic
    350z is on the dyno
    +1
    Less friction= more power, so less oil= less friction. I would not risk this. Or I would spend 10-15 more every oil change for within 5whp...
    I hate oil ****. You never know which one is suited for your car. Hell especially the climate. All I knnow is that if you start to use synthetic oil for your car around 100,000
    be prepared for some damage to your engine. Gaskets and seal start to break apart.
    I have to start looking for some new oil soon too. Ive hit 87000 miles and Im start to wonder what i should be using.
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Hm, since the topic is ''oil''......I wouldnt call this a ''gain'' or anything, but after i put new oil in my car, it revved up a LOT higher....cuz, before, it only went up to ~5 or 6 thousand before shiftin...Now, it goes complete redline, gets up there quicker, and stays up there for a lot longer of a time before goin to the next gear....Feels like a new car!
    \\\ATLANTA~ATNALTA///
    AMERICA FUCK YEAH
    im my lude, i just threw in w/e.. cheap oil, i didnt care.. its a honda, it can handle it..
    i know which oil to use, it tells me under my hood.. Mobile 1 Synthetic 0w40..
    TDR <3's TRD
    Fayetteville
    For all you non believers, go to RP's site. They have like 10 test done by independent company's, and dyno shops ect, and have proven that their oil to top notch ****. Its 7buks for a quart. not deadly expensive. Its like anything else, you get what you pay for. Higher priced oil with proven performance gains, reduced friction, a better heat transfer, and longer oil change intervals wuts not to go wrong. You can go 8k running royal purp and be fine. Thats well worth the price. even if you use napp oil, you sill are paying the same price if you think about it.
    P.s. dont add Lucas oil addtives to you car. **** makes foam....
    Quote Originally Posted by korilee13
    word but its about realistic as west side story gang fights
    88 accord
    87 rx7
    Buy my mini chopper!
    1k Killa GangstaCoupe's Avatar
    Fayette Co.
    We use either the royal purple racing I think its #7 or some other brand (I forget now, I can look it up) that is about like snake oil. Anyway both of them are oxygenated and have a few other supposed “performance" additives in them. Usually it will pick the cars up 500th's to a tenth. However its only good for maybe 10-12 runs and you will see it drop back off.
    only use AMSOIL, REDLINE AND ENEOS OR CASTROL .. THOSE ARE THE BEST
    oh and everyone
    will tell you everything!
    http://www.bobistheoilguy.com/
    My friends dad builds racing engines, and he used the dyno and tested oils and royal purple made more power(on a 302).
    ***Lotus Elise***
    BlackWatchRacing
    Mad Scientist xb1's Avatar
    Athens, Ga
    Quote Originally Posted by dubs04sti
    oh and everyone
    So true, but I still use RP b/c I hate paying shipping for Redline. And, as a side note, what certification does RP not have?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    probably canola oil
    Less friction = more power, and better gas mileage. That is why manufacturers are using such thin oil now.
