Results 1 to 17 of 17
Thread: how often should i change my oil?
    i know all
    Default how often should i change my oil?
    i have an integra gsr now, i just changed the oil with mobil synthetic, i was wondering how often do i need to change it?
    some say with synthetic you can do it every 5000-6000 miles, but ive heard others tell me i should still change it every 3000 miles
    Scottish Scotsman's Avatar
    on the road to recovery
    every 3 g's , it also depends on how hard you drive
    Senior Member antiv6's Avatar
    g-nett
    i change every 3000 with mobile one synthetic 5w20
    the more you change it the better off you'll be
    Senior Member Schugg's Avatar
    when i worked at honda i changed my oil all the time between 2000-3500. but being without working there that can be expensive ide say every 3000
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Flooding IA with JDM dc2teg2006's Avatar
    Quote Originally Posted by TheScotsman
    ditto.
    its an easy driveway job , and for a 4 banger its cheap
    Augusta, GA
    i do every 2000, cause of my driving style..
    villa rica, ga
    every 2k if you drive hard or every time you run at the track. for moderate driving and 'getting on it' every once in a while 3k is fine with a 4k max.
    good points by all the above also
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    Duluth, GA
    I change mine every 3k.
    Full Synthetic lasts a lot longer than conventional though, I'd say if you do a lot of hwy driving change it at 5-6K, if you drive it hard/short trips/race then 3K.
    Privateer Racing!!
    Duluth,Ga
    I use the same thing and i change mine out every race... So after every 20 or 30 miles!!!
    i never run synthetic.
    I run Castrol 10-40 and replace it every 3000 miles
    3k miles. synthetic lasting longer than fossil oil is a myth, neither oil breaks down anytime near 3k miles, the reason you change is that the oil gets carbon in it from the combustion process, which synthetic wont change a bit. i change mine with castrol or mobil 5w30 every 3k miles.
    i change every 4,000 b/c im running redline little expensive to change every 3,000
    Norcross
    I change mine every 2500, or anytime after I go to the track.
    2500 is also really easy to remember. do it at 2500mi,5000mi,7500,10000, and so on.
    RX-8
    208.6 RWHP
    i know all
    thanks for the input everyone
