Thread: 240sx with 300zx TT or n/a
    Senior Member sakasaku's Avatar
    Marietta, GA
    Default 240sx with 300zx TT or n/a
    Wat do you guys think cause thats wat imgoing to do and i m amsoexcited!!
    Lurking
    The Nissan KING! R32Dragon's Avatar
    Sumter
    You talk'n bout putt'n a VG30DE or VG30DETT in your 240? Better find a good shop, that swap is no picnic. Clean finished ones, however, are beasts.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    Duluth, GA
    yeap, there is more people do LS1, and 2JZ. I think LS1 is well worth it, sometimes you can get them for pretty good price from the graduation corvette.
    20 side of thangs
    2jz, ls1, not vg. looks good but i cant stand the vg30dett. IMO i would go 2jz.
    GMS1 cobalt9123's Avatar
    Winder, GA
    one engine
    CA18DET
    Iron block, holds boost MUCH better than the aluminum block sr20det, the only sr20 i'd suggest is the black top built right, the red tops are **** and blow up, blacktops are hard as hell to find with low miles also.. ca18det have a big aftermarket, you just have to order parts for a different car, whole engine/5 speed tranny is only 1400, my friend has one with a welded differential in commerce, 89 240sx with a ca18det, only thing he did was put a bigger turbo/different turbo manifold
    ran 11.9 at atlanta dragway, no bull****, it;s crazy fast.
    I'll whistle while you whine.
    2009 Summit White SS/TC
    Quote Originally Posted by sakasaku
    Why on earth would you do that? Any idea what a VG30DETT weighs?!
    In the Fucking A
    worse idea in the history of ideas.
    LS1 or 2J or SR20
    -vteckidd
    I fucked İhris's mom
    Kennesaw, Ga
    A VG30 swap would be impressive for 240SX. Though I must admit that I absolutely loath working on those engines, at least when they're in the cramped Z32.
    If you're going to do a VG30 into your 240SX then, funds permitting, go all out and get the VG30DETT. The N/A will hardly be worth the trouble once you swap in the excess weight.
    Buslengths behind you
    Quote Originally Posted by Big Baller
    LS1 or 2J or SR20 or 20B
    -vteckidd
    fixed
    The engine is cramped no matter what car it goes in, that's just the way it's built. The swap is cheap, or the longblock is anyways...i've seen the VG30DETT with low mileage go for $2,500-3,000 complete but that doesn't make up for all the excess labor and maintenance and upgrade costs. Back in the mid to late 90's that engine in 510's and 240z's was both cool and impressive, in the last 15 years there's been plenty of other engines built and "discovered" that are far better for a swap.
    Just go buy a J30 if you want that engine in something besides a Z32.
    fixed
    With the exception he wouldn't ever recommend it.
    Why not just build your own damn 3 rotor instead of trying to import one anyways? Downing has the shaft...
    Curiously Cynical DrivenMind's Avatar
    Please cut me.
