Thread: Help!
    Default Help!
    Ok I have a 93 civic LX and it idles at 1500 rpm...
    Ok here is what it does when I first I turn it one it goes from 1500 to 1000 and back 1500 and stays there... anyone know what it could be? The car drives and rides fine, but just botheres me that its set to 1500.
    What I have done!
    Adjusted the air way screw till it could not turn, but still at 1500... with all the way turned to the right.
    The cable is fine checked it nothing to do with that.
    Could it be a sensor or something any help would be great.
    1.5T AnTi-PooN's Avatar
    L'villE
    throttle position sensor messed up?
    Quote Originally Posted by -SkInNy-
    I dont know it might be.... Im going to find out tomorrow by putting a z6 tb on.
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    could be a vacuum leak. I had high idle after putting on my new intake manifold on and it was a tear in the throttle body gasket. I found it with carb cleaner. I sprayed all the joints and vacuum lines and when the idle dropped that was my leak. good luck.
    /\/\ what he said...
    x2
    Quote Originally Posted by Mad Mike
    Hmmm ill have a look and see.
    Your Moms Moderattor
    pleasant hill
    check the back of the intake manifold, there should be a little vacuum line, make sure that hose is connected, I had the same problem on my Z6. It was due to that vacuum line
    Quote Originally Posted by TheProfiteer
    Yea, I went to a shop and they checked it for free... it turned out to be the tb wrong one for the car. So, going to get one tomorrow.
