Results 1 to 17 of 17
Thread: Building a Honda kart
    Default Building a Honda kart
    Hey guys... I trying to build a kart using engine and auto tranny out of a 93 Civic. I'm trying to keep things as simple as possible and easy as possible. I need help with the wiring right now. I'm not sure what I need to keep and what I need to cut away so the engine will start. Thanks for all your help. I don't even mind paying someone afterward for helping me get this thing running. Thanks again.....
    More info.... I just need this thing running. I don't need headlight or taillights.
    FREE BUJU StarBwoy's Avatar
    IDK
    any pic
    MCD
    i would think you would even have to go as far as a gauge cluster. beacause i know my cb7 wont start without one.
    my momma's house
    Quote Originally Posted by whatever210
    really, thats interesting
    Trend settin'
    DUH-KYOO-LUHHH
    keep the ecu and the gauge cluster, all the sensors, and any electronics directly related to the motor. make sure not to cut any hoses or wires, just unplug them just in case.
    Are you sure that I'll need the gauge cluster? I didn't save that... I'll take some pics... when I make some progress...
    Macon
    I say you save yourself some trouble and go carbureted. Eleminating the EFI will help to keep it simple. I have seen a D series with a carburetor in a kart before. It ran pretty good, but not as good as any of the karts with motorcycle engines....
    Land Rover LR3 HSE
    MCD
    Quote Originally Posted by TheChosenOne
    why do you say that? does your start without one? my never does.
    IA Member K20A2_DC5's Avatar
    ATL, GA
    in for pics
    NBP K20A2
    I took some pics of the harness... My plan is to start from the ECU and end at the engine connectors. I'm not building the chassis I'm just doing the wiring. I'll post some pics when the chassis is built.
    Again... I'm trying to get the engine running make everything as simple as possible. Thanks for all your inputs.
    DUH-KYOO-LUHHH
    im gonna say that you might not need the gauges, but its better to be safe than sorry
    Post some pics of the actual cart, I've seen threads like this before but they never end up running. I wanna see this
    motorcycle engine is way easier, and you can still go w/ Honda if your dead set on it. I know, I built a nasty go-kart about 5 years ago
    ok.. changing plans... instead of building a kart.. this will be a 4 wheel drive buggy for 1 6 year old...
    Alpharetta/Duluth
    Quote Originally Posted by Jigoku Z
    Why use the auto tranny? Get a manual wire harness and run the engine direct-drive to the rear axle via a chain or belt. you will still need some kind of clutch. I would dis-assemble a manual tranny and use the bellhousing, input shaft and bearings and weld a gear onto the input-shaft and use the bearings to support it in the frame. Then you have a clutch to use without the weight of a tranny.
    slow ms6 wwpms6's Avatar
    Canton
