Results 1 to 16 of 16
Thread: 94 EG MAP sensor question
    random guy's pops!
    random guy's moms cornhole!
    Default 94 EG MAP sensor question
    ok heres the scoop , i bought my EG from a guy who hack jobbed a factory motor swap , D15B7 , i am throwin the MAP sensor CEL, that is the only code it is throwin, after further investigation i realize , there is no sensor , not on the firewall nor on the TB, so at this point i am very f'n confused , the car runs descent but i know it will run better after i install the sensor, i am gettin about 190 miles to the tank , which i now is not right , and my car is runnin a lil rich , i have had it on the lift lookin for the MAP plug and couldnt ever find one , sooooooooo i have a sensor and another full harness from another sedan , could someone please post pics of the plug and where i would have to splice into for it to work , i know i can mount it anywhere , so that wont be a prob , i did check my Chiltons , but i didnt tell me **** , and i suck at readin the wirin diagrams , any help will greatly appreciated , thanx for lookin fellas!
    dnwp
    so you cant find the MAP sensor on your current TB?
    random guy's pops!
    no sensor anywhere in the EB
    dnwp
    random guy's pops!
    looks to me there never was one on the TB
    dnwp
    random guy's pops!
    ttt
    dnwp
    There should be a plug somewhere, 3 wire. If you cant see the map sensor on the firewall, or tb then look for it hanging in the back w/ a vacuum line attached. If not, look for the connector, and put one in and attach it.
    random guy's pops!
    couldnt find the plug at all , i have an extra harness with all plugs , but dont know which one it is , also i dont know where to splice in the plug
    dnwp
    Jonesboro/Stockbridge
    Its a 3 wire. Looks a lot like your TPS plug but don't get them mixed up...
    random guy's pops!
    there is no extra plug in my EB , we had it on a lift at the shop and there was not one to be found at all , on the top or the bottom of the motor , we also traced all of the harness throughout the bay and couldnt locate an extra one
    dnwp
    Your Moms Moderattor
    pleasant hill
    probably plugged into the wrong sensor, robert I have an extra TB with the MAP sensor on it if ya need it.
    random guy's pops!
    pm me w/your # again and i'll try and meet up with ya tomorrow!
    dnwp
    random guy's pops!
    ttt
    dnwp
    Mad Scientist xb1's Avatar
    Athens, Ga
    Do you need the Factory Service Manual? Thats about the only place I know that has a good diagram. PM me if you need it.
    random guy's pops!
    i got it figured out , thanx and reps to everyone!
    dnwp
    LAWRENCEVILLE
    92-93 civic had the map sensor and harness for it on the fire wall and not part of the engine harness. 94 -95 had it on the tb and it was part of the engine harness so you need a 94-95 harness and tb and the plug looks the exact same as the tps sensor on teh side of the tb.
    random guy's pops!
    found out they had a 92 motor and a 94 harness , i had to re-pin my harness for the sensor , soon as i did cel went off and it runs like a champ now , it dropped my idle from about 1200 to about 500-750
    dnwp
