Results 1 to 35 of 35
Thread: phone jack question
    Banned s13sliderŽ's Avatar
    douglasville
    Default phone jack question
    ok so my phone jack got ripped out of the wall (long story) and its the only phone jack that works in my house , i have four spots to copnnect things on the jack and i have four stripped wires coming out of the wall does anyone know how to hook this **** back up ? the color of the wires coming out of the wall and on the jack are
    out of wall wires
    1.green
    2.white with green markings
    3.blue
    4.white with blue markings
    telephone jack
    1.green
    2.yellow
    3.black
    4.red
    reps for everyone who trys.
    Still Here LQQKITZME's Avatar
    Roswell
    you only have to connect two of them.. Red and black < phone jack side> comming out of the wall you have to test but only need 2.. only two have power you can test the power by touching it to your tounge <phone is dc current> its like a 9 volt
    View the world through a dogs eyes, if you can't screw it or eat it, pi$$ on it and walk away.
    douglasville
    i will have to get one of my buddys drunk and let them try that one out but reps for you .
    Roswell
    have a volt meter use it.. hell touch them together and you won't see a spark the voltage is two weak..
    KEITH atlvi3tb0i's Avatar
    Clayton County
    it you are useing DSL you need all the wire hook up
    douglasville
    comcast cable internet and phone service but , the internet is hooked up in my moms room from a jack and i can hook the phone up to her modem and it works but not into the wall . my jack is the only one in the house that works and i have wireless in my room so i cant just hook it to my computer.
    If you have only one phone line in your home, the red and green wires are all you need to worry about. They make the primary line work.
    You don't have any orange/white wires? Later, QD.
    douglasville
    not that were hooked up . all those are stuffed back in the wall
    douglasville
    sorry qd gotta spread my rep , i get you when i can.
    Does the blue wire have smaller white stripes on it? Later, QD.
    douglasville
    yes
    Match the blue w/ white stripe wire to the red wire and the white w/blue stripe wire to the green wire. That should provide you with a workable dial tone. Later, QD.
    douglasville
    didnt work
    I'm sorry, I don't know what to tell you then. That's how mine are wired. Later, QD.
    douglasville
    thanks anyways man , and damn you really go out of your way to help somebody . thanks a ****load bro.
    douglasville
    i touched all of them to my tounge and didnt feel ****, and i cant find my volt meer either but i get nothin on a test light
    Quote Originally Posted by s13slider
    No problem. If you're not getting any "spark," then you've got fried wiring anyways. That would explain why it doesn't work.
    The phone jack itself has only 4 pins in it? Later, QD.
    douglasville
    it has four screws on the back if thats what you mean , but from where my moms computer is wired from the cable modem to the phone jack does the same thing , gives to "spark" but our internet works.
    A little town called Nunyagoddamnbusiness
    do you have an orange wire and a white with orange stripe?
    douglasville
    yes but they are tucked back into the wall and not striped so therefore was not used with my phone/phone company but if you have any suggestions with that wire i will def. try it.
    Those are your secondary line. I didnt know if they were wired in or not (obviously not since they are tucked back). Its possible that you broke a wire when the phone jack got snatched out. You could try going out to the source and switching over to the orange group. If you do this take the blue group out, put the white w/orange stripes on the green and the orange w/white stripes on the red. Then do the same at the phone jack.
    douglasville
    Quote Originally Posted by chrisdavis
    didnt work and i gotta spread the love but i will hit you up as soon as i can and thanks for trying .
    Did you go to where the other end is wired up and switch them there as well?
    douglasville
    outside ? if so then no .
    Thats why it didnt work you have to do it at both ends.
    douglasville
    i just went oustide and couldnt even find a comcast box the only one i found was bellsouth and the test line gave the phone power but no dial tone
    Wait do you have comcast digital phone service or a regular land line?
    douglasville
    digital phone
    Ahhh. The Comcast guy should have wired the phone service into the whole house. If yours is the only one that worked (before the accident), then it may have been installed incorrectly. You may need to have comcast come back out and take a look at the whole system. Meanwhile you can plug the phone itself into the back of the modem and have a working phone.
    douglasville
    yea but when i plug it into the modem in the "phone " spot it doesnt work . i have to plug it into the modem where the internet line goes the i dont have internet . i guess i just need to call comcast . "you're a tiger now " hahahaha . but they still suck.
    Patience Pays...
    When was the last time the phone jack worked? (Very important before I answer the question)
    Patience Pays...
    Havent read the replies but with the phone jack the red and green will give you dial tone, but make sure you look at the jack and look to see if any of the copper prongs inside the jack are messed up.. if so you wont get a dial tone even if it is wired correctly.
    You said there is green and green/white wire also blue and blue/white wire. First off.. comcast technicians know jack **** about phone service so theres no telling how they wired it. But if the green and green/white (usually considered for the 3rd line but also used if the blue and orange pairs go bad) is stripped then try"
    green to red
    green/white to green on phone jack.
    I'll be back to check later
    Quote Originally Posted by tony
    green to red
    Comcast techs know jack sh!t about anything. I had them one time blame my internet not working due to a virus on my pc.....he said that because he seen a virus scan happening while he was trying to fix the internet connection problem. It ended up being the lines outside, which I was only one of several people in the neighborhood to have the problem.
    douglasville
    a week ago
    Patience Pays...
    No telling how they wired it but do as i said in the previous post
