Results 1 to 10 of 10
Thread: my breaks
    about this far.
    Default my breaks
    so when i pull up to a red light or just stop, my break pedle will be furm at frist the about 20 to 15 seconds later it will start to get really soft, or even to a point here it feels like i'm not pushing it in... my car will start to roll alittle. then if i let it out then press it back in it will so the same thing again... what can it be? rep for anyone that can help
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    San antonio 210
    same thing happen to me. 1st check to see if u have a leak any where if not check the wheel cylinders if that all ok, im 100% sure its ur brake master cylinder..
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    wheel cylinders or master cylinder
    any brake fluid leaking from anywhere?
    about this far.
    i have no leaks... hey cactus can you take a look tomorrow?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    San antonio 210
    Quote Originally Posted by callmetree19
    sure homie
    about this far.
    io cant rep you
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Ellenwood
    like I said, check the master cylinder as well, one of the internal seals could have given out or have a pinhole in it.
    Take the lines off the ,master cylinder, block them off with a bolt but dont tighten it to much or it can damage the master cylinder, an mash down your peddle, if it is hard an dont go down you have another problem , but if it leaks down soft you need a new master cylinder, to take off your lines, use a 10mm Flare wrench only
    college park
    sounds like a master cyl. to me go to autozone and pick one up shouldnt take you more than 30 min me and a buddy just did it on my hatch last weekend
    now with LSD
    Mad Scientist xb1's Avatar
    Athens, Ga
    if you drive on it too long you can cause the booster to leak as well, so fix it sooner rather than later.
