Results 1 to 11 of 11
Thread: what's needed for a cd player to power on?
    Augusta, GA
    Default what's needed for a cd player to power on?
    what's needed for a cd player to power on? i know power, and ground. anything else.? I need to do some diagnoising. to see which of what i'm not getting.? thanks.. it is in an integra.
    ATH GA. SRCRX's Avatar
    On the drum set!!
    what car and I can give you the wires colors
    On the drum set!!
    12v white/blue
    Ground black
    Ignition yellow/red
    (92 TEG)
    I GOT IT!
    Jan 2003
    Lithonia, GA
    12 volt contant, 12 volts switch/Acc and a ground
    Hybridaccord
    Hampton, Ga
    power and ground
    Quote Originally Posted by b17a1db2
    when u get your fixed come and fix mine.
    -IA MGMT is inappropriate.
    Wasting Fossil Fuels n2daizo123's Avatar
    Most of the time when you have the everything hooked up right and it wont cut on do this: Disconnect the ground wire, find a good grounding position (one of the shifter bolts) and run a direct ground to the cd player. If that does not work try and hook the 12v constant from the car to the 12v constant and the ignition/acc and see if that works if it does you have a problem with the acc wire. Most of the time its a bad ground though.
    Check the fuse in the back of the deck (if it has one).
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
    Toyota Tech
    Dec 2003
    Claxton, GA
    fuse back of deck, any inline fuses for the 2 pwr lines, and the car's radio fuse (should be in fuse panel)
    for testing purposes you can wire the two 12v (ign and constant) together just to see if radio comes on
    Augusta, GA
    thanks for all the replies.. i know i hooked it up right, but it's just not coming on.. so i figured i'd be doing some diagnoising.. it's way to boring to ride w/o a radio...
    I GOT IT!
    Jan 2003
    Lithonia, GA
    try the cig light fuse, some cars run the radio and cig lighter on the same circuit
    Hybridaccord
