Results 1 to 5 of 5
Thread: Brake Assembly is Wabbly Like the Hot Boyz
    West Staines
    Default Brake Assembly is Wabbly Like the Hot Boyz
    do i need a new wheel bearing?
    Just the brake assembly or the wheel/hub itself? With the car parked and not jacked up what happens if you push the top part of the wheel/tire towards the car? Then with it jacked up (and in gear) is there movement when you grasp the front and rear of that wheel/tire and shake it?
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    check your tie rods also
    That ball joint could be back too.
    "big $hit poppin"
    in the slums where killas get hung
    when does it wobble wobble? when u apply the brakes or while under acceleration?
    if while braking, your rotors could be warped-resurface if above min. machine limit or replace if below.
    if under acceleration-loose or worn susp. parts, a tire maypop, bent rim (oops, u might not want to know that, sorry) or just simply out of balance-replace what's necessary!
    & last i forgot... if you hear a roar (roadnoise) that seems to get louder as you drive faster- wheel bearing assembly or tire maypop
    if i knew what the fuck "wabbly" was i might be able to tell ya.....
    EF SQUAD FTMFW!!!!
