Results 1 to 33 of 33
Thread: How do I pull 400WHP out RB20?
    Banned \\'angan's Avatar
    Default How do I pull 400WHP out RB20?
    Need to know how to pull 400WHP out RB20DET?
    Will a GT35R do that? With the right parts?
    What parts do I need to keep it reliable, like fuel pumps and such?
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    sell it and buy a b16 LOL
    j/k
    PM Halfbaked
    j/k
    Good laugh...but recently found out that VTAK and turbo don't mix to well!
    TUH....URBO
    EF SQUAD FTMFW!!!!
    a bigger turbo
    i'm a got dang wallaby!!
    FMIC, Boost controller, Turbo back, bigger turbo VIOLA
    The Nissan KING! R32Dragon's Avatar
    Sumter
    Cant forget fuel. With 400whp on tap, that RB is gonna be thirsty. Plug up some 555 nismo injectors (or some other bigguns) with a Walbro fuel pump.
    Tuned ECU.
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    Turbo, 255 walbro fuel pump, 550cc injectors, manifold, 3" down pipe w/ 3" back to can... I can get you ANYTHING you need for an RB20, PM me and Ill give you my number. VISION performance, we are building an RB25 for an s14, 2JZGTE for an SC300, RB26 for our R32 right now so some stuff we have in stock. LMK Peace Brian
    GL on whatever you do!!
    Untouchable
    Oct 2003
    sell it and get an sr
    05 DG G35 Coupe HIgH_ScHoOL's Avatar
    Quote Originally Posted by Nyteryder
    agreed
    Fujita SR|M2 Performance KCR X02|'07 Projectors|iPod Interface|Mucho LEDs|Axis
    "Stay hungry. Stay foolish"
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    x2 on PMing halfbaked, he knows those in and out and how to make crazy power on stock block/head rb20's
    ☠Young Harris☠
    SR is a bad BAD ass motor, but if you already have the RB then build it... They can turn some pretty sic RPMs with a stock bottom end... But its all on you man
    2>4 StupidBikerBoy's Avatar
    Macon, Ga
    do some research on these sites, they have lots of info on RB's.
    www.freshalloy.com
    www.nicoclub.com
    www.racebread.com
    turbo ,injectors, headgasket, headstuds, EMS
    Woodstock
    400 shot of
    Val RIP
    my only rule in life
    just kill curry man,.
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    rb20.......built it or 400whp will cause you to build it after about 2 mins on stock rb20 and 6.5k under full boost. Or get sr?????? It would be cool to see a 400whp rb20....prbly not to many of those floatin around in GA or the US for that matter. GL anyways
    agreed
    Quote Originally Posted by highspeed
    wha? there must have been some words left out bec i didnt understand anything just said here....explain
    Sumter
    He no speaka inglish.
    Quote Originally Posted by \\'angan
    You can easily get 400whp from a RB20 with a MugenArt ECU reflashed to pre OBD4 and a Nismo chip, a new turbo, all soft charge pipes to prevent heat, direct feed oil into the turbo, Nismo FPR, and a 2 inch thick throttle cable for best performance when opening the TB under extreme pressure. That's what my buddy did it has 403.21WHP and 397foot pounds of push.
    Earth
    He's saying you need to fully build the block, because with stock internals @400 hp... the first time you hit full boost at 6.5k rpm the motor will frag and you'll be forced to build it then.. because your rods will be in pieces.
    Broke sullen's Avatar
    Acworth
    fuel pump, pistons, cams, bigger turbo, fmic, turbo timer, boost controller, turbo back exhaust. basically, lots of money. dont forget the tuning time...
    we just started to build one hoping for 450+ whp ill make a thread sometime about it
    ☠Young Harris☠
    stock bottom end is good for 5-600hp... no more than 16lbs though...
    20 side of thangs
    you would be suprised how many there are. tophat has built a few 400hp+ rb20 cars. I still see 3 of them on a regular basis because i know the owners. I am know they have sent a few motors out of state from when i use to work there.
    its not hard to get 400hp safely out of an Rb20
    call top hat and ask for scott.
    770-388-5233
    JDM TYTE AnthonyF's Avatar
    a 400shot of nitrous.
    The Carbon Fibered R6
    Belview Insane Asylum
    That's because the only thing RB20s are good for are boat anchors.
    if you swap the gallo 22 head and do a port polish, youll be gold
    hmm..possibly but not without a double shot of nawz... like i said..two 200 shots of nitrous=400 should do u right...watch for the floor mats..they tend to fall out.
    ☠Young Harris☠
