Results 1 to 33 of 33
Thread: FS: 1991 s13 hatch w/sr20det
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    Default FS: 1991 s13 hatch w/sr20det *Price drop* $5000
    1991 Black Nissan 240sx LE w/SR20det
    $5000 obo
    WILL NOT PART OUT
    Oil changed religiously before and after every drift event
    Or around 1500 miles which ever came first (no really, this is not an exaggeration)
    Only used Mobil 1 and Purolator PureOne oil filter
    Redline Synthetic oil used in Transmission and Differential
    APEXi SAFC 2 installed
    Car was tuned by TopSpeed
    For 280 hp @ 20 lbs have dyno sheets to prove it
    I keep it at 15 lbs.
    Blitz SBC idIII electronic variable boost controller
    Precision front mount intercooler
    Custom stainless steel intercooler pipes all Tig welded
    1. Stainless steel t-bolt clamps
    2. Multi-layer high grade silicone couplers
    New Greddy type-rs blow off valve (sounds good)
    Upgraded turbo S15 turbo (gt28r) dual ball bearing
    3in Apex N1 exhaust cat back (w/urethane hangers)
    Enjuku racing test pipe installed (NO CAT)
    3in downpipe
    3in o2 extension installed
    Z32 Mass Air Flow meter
    Electric fan
    Custom made intake
    Greddy roller-rocker stoppers installed
    Subaru STI 550cc injectors installed
    Thermal intake manifold gasket installed
    Nismo engine mounts
    Peak Performance tranny mount
    New 3 puck Exedy Clutch (fresh with less than 3,000 miles on it)
    Custom Aluminum driveshaft
    Unorthodox Racing Aluminum Main Pulley
    Enjuku racing aluminum accessory pulleys
    Nismo lower temp thermostat
    New water pump
    Upgrade radiator copper Koyo
    Battery relocated behind passenger
    Wire tucked and cleaned from engine compartment
    Carbon Fiber spark plug cover
    NGK iridium spark plugs new (just installed)
    New heater hoses installed (enjuku kit)
    KYB AGX adjustable shocks & struts
    4 way in the front
    8 way in the rear
    Eibach Sportline Springs installed
    Project Nissan rear upper control arms
    Aluminum Subframe spacers installed
    Peak Performance rear toe control rods
    Whiteline adjustable Front & Rear sway bars installed
    3 way in the front
    2 way in the rear
    Nismo Powerbrace
    Pro-thane Urethane bushing installed in Front Toe control rods
    300zx Brakes (26mm) installed up front (will clear stock 15” rims)
    Cross-drilled and slotted rotors all around (drilled for 4 lug)
    Braided stainless steel lines all around
    Hawk performance pads installed in rear
    PBR Ceramic brake pads up front
    Q45 master cylinder installed
    Chassis has 240,xxx miles on it motor has about 55,xxx on it
    I am the seconds owner of this car and have had it since the year 2001
    Car has factory sun roof
    Viscous LSD put in at about 2 years ago works great
    Abs on car (disabled)
    Dash has one crack (happened a couple winters ago)
    Electric windows
    Electric mirrors
    Electric locks
    Cruise control (disabled)
    Canadian daytime lights up front (w/led bulbs) wired to running lights
    Car has been gutted
    AC has been removed
    Car has minor cosmetic defects dings and dents
    A couple of major dents (one from a cone and the other from when someone broke into my car)
    New front fenders and bumper
    Does have power steering and is working
    2 sets of 4 point Sparco harnesses
    Custom harness bar w/ camera mount installed
    Autometer gauges (boost, watertemp, a/f ratio)
    Custom carbon fiber behind gauges and radio
    Sony CD player w/ Aux input
    Peak Performance extended wheel studs up front (20mm)
    Light weight lug nuts all around
    16” Enkei RP01 Rims with Hankooks Ventis Rs2 Z212
    16 x 7 with 215/45/16
    16 x 8 with 225/45/16
    with plenty about 75% of tread left
    Car has been well maintained and I really hate to see it go but the time has come to move on. No trades. No low balers. No scammers. No joyrides. The car just needs a little cosmetic TLC. Please only serious buyers please.
    Please email if interested.
    [email protected]
    GeckoSquad / Skull Platoon
    29th Chamber
    oh yeah the vin is JN1MS36P3MW022677
    wow, what a beautiful car! Too bad I dont have the money. But this car will someone really happy...
    i'm a got dang wallaby!!
    BRENT! WHERE THE F have you been hiding thiS?!?!?!?
    and noooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    29th Chamber
    hahaha its my roommates car lol!
    Atl
    cleanahell
    IA's culinary pro TheGrillMan's Avatar
    holy e-brake batman
    someone should buy this car
    29th Chamber
    29th Chamber
    bump ****price reduced****
    No
    THE FUCK?!
    Why's he getting rid of it?!?!
    got billz to pay...It sucks and i don't want to do but I hafta
    Henry Co.
    trade for ka powered 240 plus cash?
    29th Chamber
    Quote Originally Posted by RobbieDB
    THE FUCK?!
    b/c you touch yourself thats why!
    IA Member GTP_Power!!!'s Avatar
    I would trade you my car but it sux so...but damn, if i had the money!
    young, hated, ridin clean JDM_Dominican's Avatar
    Cumming, Ga, USA
    could AC be reinstalled?
    if so, what would you say to the idea of this car as a daily driver?
    NYY - CFC - BIG - ROC - NJN - UGA - JDM
    hustler ksniperfox's Avatar
    lawrenceville
    Quote Originally Posted by JDM_Dominican
    your link dont work.
    free bump, clean car
    drives a trycicle
    newnan
    free bump.
    see ya 240love.
    It used to be my daily until last year when I bought a beater (88 mazda 626) to get around in...
    -By the way, I am the actual owner of this car-
    And yes AC could be reinstalled -it would need a compressor and evaporater and dryer- the AC hook up lines are still on the firewall
    ttt
    nice ride
    140 on one wheel
    columbus, ga
    pmed you!
    ttt
    looking for trades?
    140 on one wheel
    columbus, ga
    still forsale will you take 4000?
    Untouchable
    Oct 2003
    I am very interested send me a pm if it is still for sale
    pm sent
    ooo n/m on pm
    IA Member SAV Racing's Avatar
    awesome car!
    ok pm sent again
    bump for nice car
    pm sent
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    damn, trade for a 91 supra?? (7mgTe)
