Results 1 to 11 of 11
Thread: D16A6 reving up and down after jumpstart???
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Question D16A6 reving up and down after jumpstart???
    Problem started after I jump started my car because I left my LED interior light on for 4 days. I didn't notice my ignition was in the on position when I hooked up the cables between my ford van(high output alt. for all the equipment I have to use at work. I've jumped many cars off with this van with no issues.)
    After my car warmed up like normal (idling at 800-1000RPMs) it started to rev up to about 1500-2000RPMs and then down to about 500RPMs then back up and so on. The car runs fine while driving or if you give it a little gas.
    No CEL but was flashing a 7 and a 14 from previous trouble shooting. cleared the codes and they haven't came back. swapped ECU for a known good one with no change.
    If I unplug the IACV it reves up and down faster. if I unplug TPS its goes normal. I checked the voltage coming from the plug to the TPS and it has 7V. My honda service manual says to hook up a test harness and check voltage but I have no idea where to get this harness. Also I sprayed carb cleaner at all vacume leak areas and no change in idle.
    Can anyone give me some advice to get this problem solved?
    thanks
    my turbo is bigger! revsk8erdude's Avatar
    Blairsville
    i had the same problem wiht both of my hondas.
    try unplugging all the air sensors and plugging them back in, and your throttle cable may need adjustment.
    its a common honda problem. no big deal really. worst thing that could happen is replacing your sensors.
    no biggie.
    rep me plz.
    WTB: My own forum, so I can badmouth IA.
    about this far.
    check the t/b gasket mine did that shit,
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Gainesville
    I've sprayed carb cleaner all over the joints and there no vacume leak. All gaskets are new they where replaced about 4 mouths ago.
    I've unplugged and replugged all sensors and no change. all connections are good and tight.
    tps should be koeo .45v and 4.5v wot. if it's reading 7v something is wrong and should throw a cel. more than likely your problem.
    Gainesville
    7V was from the plug that plugs into the TPS. between 2 of the 3 wires.
    San antonio 210
    srill not running right ?
    Gainesville
    Nope
    Drives great with the new motor mounts and inserts. Launches hard with vary little wheel hop due to the traction bar. But idles like hell. I got to drill out the mounting holes on my spare throttle body/TPS and see if thats fixes the idling.
    Macon
    if it didn't do it until you jumped it off, then its probably the tps.
    Land Rover LR3 HSE
    pop of the cover of the ecu and check the voltage at pin d11 and the bolt where the ecu bolts to the body. it should be .45 koeo no throttle and 4.5 koeo wot. i never check it the way you did so 7v doesn't seem right.
    Gainesville
    Well shit I replaced my TB with a new/used one off a runing car and the reving up and down stoped. But when I took it back off to clean and paint it I broke the vac. fitting for the map. So I just put my old one back on While I waited for the JB weld to cure and the reving was normal. Drove it in stop and go trafic for almost 2 hours and it idled fine. Had to of been a vac. leak or a short in the wiring. Hopfully it won't come back. thanks for the help
