Results 1 to 40 of 43
Thread: damnit, blew my motor
    02 WRX patrick4588's Avatar
    warner robins
    Default damnit, blew my motor
    i have a turbo gsr and my ringlands are toast. did a leakdown today and cylinder 3 is 88% rofl. the others were around 10-15%. so im gonna rebuild it with forged pistons and rods. any suggestions on brand. only shooting for about 350whp on full boost. about 290-300 for daily. going with stock bore and compression btw.
    140 on one wheel
    columbus, ga
    How long did your motor last? what psi where you running now? and how much power was you making?
    140 on one wheel
    columbus, ga
    oh and btw cp or srp pistons and eagle rods FTW!!
    Eagle ROds and use CP pistons
    i can get good prices on them too if you need them.
    MAKE SURE YOU TUNE IT AS WELL
    YEAH! bRiAnMcIvIcS's Avatar
    As far as pistons you could use arias, wiseco, or CP. Rods just go with Eagle.
    warner robins
    Quote Originally Posted by Gr33n_EK9
    it only lasted 2500 miles, simply because i was on a basemap and took forever to get tuned. so its my fault for not tuning. im not sure what hp i was making, when i got tuned it was only a street tune, but i maxed out the stock map sensor.
    warner robins
    put new rings in it and call it a day
    JJSPEC.COM
    warner robins
    well if im pulling the pistons out, i might as well put forged ones in right? but then again, i dont feel like going without my car for a month... how much would oem rings be?
    need to pull it apart. if the pistons have collapsed ringlands, new rings will not solve the problem
    warner robins
    well i wont know till i get it apart so i should probably get on that.
    JDM TYTE AnthonyF's Avatar
    id go with CP. I have Wiseco in my car and ran 3 months with a lean piston and it held up forever!
    The Carbon Fibered R6
    warner robins
    who will be rebuilding your motor
    JJSPEC.COM
    warner robins
    im gonna try to do it. got a helms manual and some tools.
    warner robins
    how are the wiseco doing? i found a good deal on them combined with eagle rods and arp rod bolts
    Not sure how much you were making? By street tune do you mean mild tune on a dyno or physically on a street making minor adjustments with whatever you can turn with a screwdriver?
    warner robins
    street tune as in a wideband and crome pro. jkobd tuned it for me. it was done on the street, not a dyno. the tune was good, i just screwed it up by riding on a basemap for a month and a half...
    warner robins
    i rode on a basemap for 10 months with my old civic with no problems
    JJSPEC.COM
    they are fantastic.
    I had an injector clog (paper in the way...dont ask) for 3 months on 13psi every day and it took A LOT to melt the piston. And it barely melted. They are very strong. I still have a few at the house (back ups, i kno they wont fit ur car) if u want to see or whatever. I love them to death and there customer service is AWESOME!
    they are fantastic.
    You mean you're supposed to take them out of the plastic wrapper before you install them?!
    hahahah
    no...worse...
    i painted my rails red and put paper in the injector ports...and forgot to take one piece out...
    warner robins
    Quote Originally Posted by d16_turbo
    you know that doesnt mean anything man. your basemap could have been a better guess than mine.
    warner robins
    it means my cars are way better than yours
    JJSPEC.COM
    warner robins
    because your basemap was a better guess than mine?
    warner robins
    yes
    JJSPEC.COM
    warner robins
    i wonder if jerry or jeremy or whatever will talk shit to me now since im not running. rofl. at least he doesnt have a hole in his hood.... lmao
    warner robins
    he prolly will...... i cant i have blown motorS before
    JJSPEC.COM
    warner robins
    it could have been a lot worse, i could have slung a rod thru the block or floated a valve or anything like that. just rings gone isnt so bad.
    middle ga
    i have been ridign around for 6 months or more on a base map...ran low 12's...over boosted many times...(17psi) revved to 9500rpms...all on a stock gsr. no probs yet. if you did some major damage its most likely due to your motor not being up to the task of boost moreso thatn the base map being that far off. jason has been good to me and kyle with the base maps. true they are only to get you going till you can tune...but a basemap for a stock gsr with a 60 trim and 550's...there are millions of them. and imsure they are all very similar....may not be dead on but close enought o run a car good...hell i ran 12.2@116 on a base map and stock motor, kyle ran 12.8 on a base map and stock motor. its shitty the at this happened but its not just the base map...the motor has to be ready for the abuse too. i think the prob was most likely that while you were untuned your car was not making near the power it was after the tune..and thast why it fucked up after the tune. it was making more power with a good clean tune and teh shit in your motor couldnt handle it. didnt you say the previous owner rebuilt the motor or somehting...what did he use for internals?
    warner robins
    honda rebuilt the motor like 63k miles ago. i did a compression test before i put the turbo kit on and it was like 220 across the board. i dont remember the exact numbers, but they were all like 218,221,etc...
    140 on one wheel
    columbus, ga
    Quote Originally Posted by japan4racing
    damn what psi were you running on that basemap?
    middle ga
    10 psi...the last run of the night was 12.4 on 8.4 psi...same turbo patrick4588 has except im in a civic
    Hwy 315
    ^ quote of the millenium
    too bad that's longer than 50 characters, or else I'd put it in my sig.
    [/URL]
    Jesus Christ is my Savior
    Sorry to heaar that.
    Quote Originally Posted by DB1_77
    hahahah u like that right! i want damn reps if u use it! lolol...but its true..
    140 on one wheel
    columbus, ga
    your brave running 10psi on a basemap...lol
    warner robins
    so i pulled the head today and everything seems to be in ok shape. cylinder 3 piston looks like part of it melted (not bad) and caused a open spot near the cylinder wall. the rings are toast but the walls looks to be ok. im hoping to get away with getting a good hone and throwing some new pistons and rings in. i got some pics and ill get them up in the morning/afternoon
    middle ga
    ive ran more than that. the map is from a gsr with the same turbo/fuel system and 10 psi. it runs ok...ok enough to run low 12's. wheni tune it im gonna crank theboost up more. fuck it. i have had this motor for 3.5 years now and boosted it twice. if it blows up its no big deal.
    glad you got your shit taken aprt ..now get it back together and save for that sleeved block and some good internals. build it right and be happy
    140 on one wheel
    columbus, ga
    Nice...how many lbs you cranking it up to? what size slicks were you using when you ran that 12.2?
    'Round These Parts
    I started laughing in this thread somewhere around post # 22
    nice
    Leisa and S. 4 Life NM?
    warner robins
    the crazy thing was on that 12.2 pass he only cut like a 2.1 or 2.0 60'. 11s were definitely possible that night if the 60' would have been a little lower.
